Results 1 to 8 of 8
Thread: wierd noise
    alex
    Inner West Lad
    Default wierd noise
    hey guys, my ke70 is making a clicking noise whenever i steer left or right . Any advice on wat it is would be good.
    Jul 2009
    Daniel
    Morisset
    more info ... full lock , any type of turning force?
    check the bushes and uni joints
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    Talking
    check that inside wheel weights aren't hitting the strut or or anything like that
    Brandon
    Blackwater
    i got the same problem mine are the bearings in the top of the struts, pulled the bearings out n repacked them but few 100k's later noise started happening again, tried to find some bearings to replace them but can only get genuine toyota ones 200 bucks each! might be able to get other bearings from a bearing shop if i was to take them in but i cant afford to have the keto off the road.
    urs may be a different problem though
    but yeah as faceplant said check the bushes and uni joints first
    Michael
    Crimebrook 2749
    Talking
    sure you packing them with HTB(high tension bearing) grease other wise the greese just turns to like oil and fucks off
    Brandon
    Blackwater
    yeah used htb, was all done right old man was a motor mechanic for 20 years so he was there giving a watchful eye hahaha
    Site Supporter Javal's Avatar
    Josho
    Re-greasing won't fix a collapsed bearing. Remove strut top, stick finger in bearing and rotate. If it's crunchy as shit, remove, clean, if it's still crunchy, replace.
    KE70alex, more information required.
    Senior Member spoon's Avatar
    Oatlands
    do you have coilovers with standard strut top? if so, its probably the spring hat not seating against the strut top bearing - try putting a spacer in between (washer).
  1. Wierd timing issue...
    By jaydos in forum Technical - Questions
    Last Post: 12th October 2011, 09:34 AM
  2. brakes feel wierd.
    By Ade_Mc in forum Technical - Questions
    Last Post: 3rd February 2009, 01:37 AM
  3. wierd toyota photos
    By haado gei in forum Toyotas in the Media
    Last Post: 30th July 2007, 04:21 PM
  4. wierd noise
    By callum1 in forum Technical - Questions
    Last Post: 24th June 2007, 07:27 PM
