this is off the hook
Price: $23,000.00 12 months rego and engineered. FIRM and ridged! Just like me after a good fishing story!
1986 Trueno ae86 GTV (yes real JDM omg!)
The car is super light (920kg)
Engine:
SR20det S15 engine
6spd
Alloy 50mm Radiator
Speed flow fittings and braided everywhere!
Alloy Intercooler
Earls oil cooler core
Fuel System
- 6 Braided fuel Lines from Engine to supply system (ie:back of car)
Fuel Cell
Drivetrain:
6 spd box fresh rebuild
Braided Clutch line from master
1pc Shaft
hilux Diff (out of the Dirty Ibis)
Mini spool Centre
Custom mounts
Suspension:
Greddy Suspension
Cusco Castor rods and brackets
Nasiga Rose Joint Tie rods
AJPS Lock Spacer
Cusco 30mm Rcas
AJPS Corona Arms
26mm Sway Bar (f)
Apex Trailing Arms and Panhard rod
Whiteline Traction Brackets
17mm Adjustable Whiteline Sway bar (r)
AJPS Rack Bushings
Brake System:
Willwood T3 Front Brake set up
Willwood Bias Adjuster
Hydro handbrake
R31 Rear rotors
R31 Rear Calipers (foot Brake)
VS Commodore rear Cailpers (Handbrake)
Custom Brakets and lines.
Rolling Stock:
Black 15 x 8 -4 Superlights (x6)
25mm bolt on spacers front and back
Body:
Completly stripped.
Origin Rear Bolt on Flares
Origin Front Fenders 25mm
Jblood carbon Bonnet
Beau made FRp hatch (3kg)
Polycabonated rear QTR windows
Bits here and there removed and modded.
Inside:
Zeta Driver seat
custom cluster with defi copy guages
in car bias adjuster
custom loom
21 point bolt in cage. (it'll do for the time being)
AJPS Harness bar
2 in the pink 1 in the stink
cant beleive u can bring urself to sell it. such a nic car with EVERYTHING done to perfection.
Dissapointed
It wont happen so keep your skirts on..
But if someone has the cash.. cool... i can build anything
buy a mk 2 or something balla, so you can also get away with streetin it
Mk no!
Id build this
imagine attemting to slide that.. you can do it beau
lol slide rod, do it beau.
