Results 141 to 150 of 631
Thread: JDM BEAMS Notchback track build
Threaded View
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default JDM BEAMS Notchback track build
    well it seems ive finally joined the light, or the dark side mabey even but ive finally got my self my dream car and settled on my plans.
    spec list so far.
    frp boot lid with jdm latches
    nagasa strut tower braces
    nagasa inner guard braces
    cusco tri brace in boot
    modded tunnel for new motor/gearbox combo
    front ae86 guards welded on the rear
    suspension ive been hording
    front:
    24mm selby sway bar
    rebuilt xt130 lcas
    power steering arms (ae70)
    rack bushes
    lock spacer
    braded brake lines
    falcon king springs in ke70 struts (will upgrade to coilys when i can afford it ill lose my ps arms when i go ae86 struts)
    kelway strut brace but to suit ke70 so anyone wanna swap?
    rear:
    230mm ajps 6kg springs (wanna upgrade to adj. seat 5kg spring wanna go an lnch lower at least)
    adj. selbys swaybar
    adj. ajps panhard
    kyb exel g stort strokes
    motor:
    black top quads
    20v to beams adapter manifold
    future mods
    ant has said the beams will arrive in his workshop in about 3 weeks
    in that time i'd like to do the following
    finish welding the tunnel
    fix up the guard
    touch up a few things like stone chips and cracked bog
    seam weld it while its all out as i might go rose joint 4 link one day
    repaint the inside as it'll be fucked from the welding
    and then give it a buff
    then i'll start to fit beams but it'll probley take me a while to save for the ecu and wheels
    now i'll let the pictures talk
    and also big thanks to jay for the car such a perfect base cant wait for beams tandems
ID:	8682   Click image for larger version.
ID:	8683   Click image for larger version.
ID:	8684   Click image for larger version.
  1. Beams KE10 Build
    By Jordain in forum Other Toyotas
    Last Post: 10th June 2016, 10:41 AM
  2. Just JDM Imports Track Car Build
    By 44GTE in forum AE86 Owners Forums
    Last Post: 24th July 2012, 11:00 AM
  3. WTB: JDM trueno notchback.
    By zacnsw in forum Cars or Parts Wanted
    Last Post: 4th August 2011, 01:34 AM
  4. jdm notchback levin.....
    By john84ie in forum Cars for Sale (Toyota Only)
    Last Post: 14th May 2011, 11:17 PM
  5. EOI:clean jdm notchback shell
    Last Post: 25th April 2011, 10:12 PM
