Page 56 of 64 FirstFirst ... 6 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 LastLast
Results 551 to 560 of 631
Thread: JDM BEAMS Notchback track build
  1. #551
    Glenn ke_70's Avatar
    Clay
    Barossa!
    well more drama as this car has seemed to attract so well...
    fixed timing belt, cas, ect ect. that all went sweet apart from the tensioner mount shearing off, that was easily rectifyed though.
    car is only running on 1/2 cylinders and mabey intermitantly on no.3 (odd bang every now and the plug's black)
    i've checked and checked again, cam timing is good. belt and cam pully's are exactally where they should be/
    compression is good, 160 psi across the board
    new spark plugs
    tryed running different tunes through it
    get's spark across all 4 cylinders
    fuel pressure's good
    swapped coilpacks around with same result's, assume all are good here. (no rings either)
    not out of idea's yet, i'm fairly i've blocked up the injectors, i ran the fuel tank fairly low so it might have picked up so crap.
    the fuel is easy 6 months old, that probley not helping but not the problem.
    so will drain the tank and flush the system. and see if theres a way to clean injectors by myself? ideally i should take them somwhere but don't have time.
    will throw a timing light on it tomorrow as well to see it they are actually firing at the right time also.
    if it's non of the above then im fresh out ideas...???
  2. #552
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    lebo injector clean
    block return(or run pump at max pressure) and thrash the #### around the block
  3. #553
    Michael
    Crimebrook 2749
    run it and get a vacume guage on it, can tell you alot (valve condition) comp test will only tell you so much
  4. #554
    Clay
    Barossa!
    i was thinking of just doing this, exept i can manually pulse any injector with the adaptronic. so i should be able to give em a rough clean like that fairly easily and safely.
    i could try cranking the fuel pressure up first though?
    the head has only just been rebuilt, so im assuming unless it's had a catastrophic failure with the valves it should be good. should at least fire if im getting high comp readings.
  5. #555
    Veteran Pidgey's Avatar
    Sep 2009
    Ry
    Sunshine Coast
    Best way to clean injectors!
    Maybe since your Nissan isn't running, it's transfering all the Nissan AIDS to the other car in the garage?
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Jacobxxx View Post
    I will legitimately drive nude...
  6. #556
    Clay
    Barossa!
    quite possable they're both rubbing fail on each other.
    mabey they're just both pissed i bought a dirty stinkin old holden?
  7. #557
    Veteran shift_rook's Avatar
    SE Burbs
    Yeah was going to recommend using carby cleaner like that. From what i've seen works well
  8. #558
    Gunner
    Run some of that subaru/threebond upper engine cleaner through them clay, shit works wonders.
  9. #559
    Clay
    Barossa!
    alright, i can not get this running!
    i've now tryed everything, i've interchanged the injectors between 1,2 and 3,4 now and still same story, running on only 1,2
    and have manually pulsed each one as well
    that rules out injectors.
    i've now checked ignition timing and 1 and 4 are the same at 15 degrees as they should
    so all ign timing is in check and is getting spark.
    there is strong compression
    fuel pressure is strong and steady
    fireing order is correct
    fuel, spark and timing. im getting these 3 elements so i should have a perfect running engine!
    i've cross checked both injectors and coil packs and they are good so i don't understand?
    anyone got any ideas? i can only think ecu now?
    is there any sensor on the beams that would stop 3,4 from firing?
  10. #560
    Gunner
    Moved any wiring around? Might have some interference in a circuit somewhere?
  1. Beams KE10 Build
    By Jordain in forum Other Toyotas
    Last Post: 10th June 2016, 10:41 AM
  2. Just JDM Imports Track Car Build
    By 44GTE in forum AE86 Owners Forums
    Last Post: 24th July 2012, 11:00 AM
  3. WTB: JDM trueno notchback.
    By zacnsw in forum Cars or Parts Wanted
    Last Post: 4th August 2011, 01:34 AM
  4. jdm notchback levin.....
    By john84ie in forum Cars for Sale (Toyota Only)
    Last Post: 14th May 2011, 11:17 PM
  5. EOI:clean jdm notchback shell
    Last Post: 25th April 2011, 10:12 PM
