Page 57 of 64 FirstFirst ... 7 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 LastLast
Results 561 to 570 of 631
Thread: JDM BEAMS Notchback track build
  1. #561
    Glenn ke_70's Avatar
    Clay
    Barossa!
    havn't really touched any wiring. is all still in perfect condition, nothing rubbed or melted or anything.
    it all pretty simple just coils, injectors, vvti controllers, cam triggers, cas, water temp, map sensor, tps
  2. #562
    Gunner
    Quite simply clay, its more than likely a signal issue. So either interference, a dud pick up, or a dud ecu. Id be tryig the easiest cheapest option first, and by-passing the loom in the car, just to rule out interference (it happens more often than most people realise) then sensors/pick ups, looking at the units themselves aswell as mounting points (cracks etc) then look at the ecu.
    If you have everything it needs to run, spark, fuel, comp at the right timing and then it doesnt run when its together, youve either missed something stupid, or its a signal issue, it cant be anything else.
  3. #563
    Clay
    Barossa!
    yeah who knows, it's beyond i think.
    sending ecu and all the sensors to anthony so he can check ecu/wiring for faults and run everything on another beams.
    im pretty much hoping it the ecu at this stage.
  4. #564
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Get a decent ecu/tune... problem solved
    Andy
  5. #565
    Gunner
    This got an adapt in it?
  6. #566
    Clay
    Barossa!
    yeah adaptronic.
    i'd like an autronic really but there's no avalible plug in looms like there is with the adapt's
  7. #567
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    because paying someone to make you a loom is so BULLSHIT high priced, for a car like this......
  8. #568
    Gunner
    Spend the money on the autronic, you wont regret it
  9. #569
    Glenn
    North Ringwood
    or a motec m400 and i will give you a start up map
    a guy in the states bought a adaptronic and from new was having problems with it ,turned out to be a bad ecu and the guys sent him a new 1
    so could be maybe a bad batch and maybe yours could have a problem as well
  10. #570
    Clay
    Barossa!
    eventually i will when i start building the engine, as i will be running outboard injectors when i get around to machining up my new throttle bodies.
    tims seems to run like a dream on the adapt.
  1. Beams KE10 Build
    By Jordain in forum Other Toyotas
    Last Post: 10th June 2016, 10:41 AM
  2. Just JDM Imports Track Car Build
    By 44GTE in forum AE86 Owners Forums
    Last Post: 24th July 2012, 11:00 AM
  3. WTB: JDM trueno notchback.
    By zacnsw in forum Cars or Parts Wanted
    Last Post: 4th August 2011, 01:34 AM
  4. jdm notchback levin.....
    By john84ie in forum Cars for Sale (Toyota Only)
    Last Post: 14th May 2011, 11:17 PM
  5. EOI:clean jdm notchback shell
    Last Post: 25th April 2011, 10:12 PM
