Results 1 to 6 of 6
Thread: AE92 flywheel into T50 gearbox?
    Jan 2010
    Peter
    ACT
    Canberra
    Default AE92 flywheel into T50 gearbox?
    Car - Datto Ute
    motor - 4AGZE
    use - Street
    problem - Flywheel
    occurs/started when -
    personal situation - I have pulled a 4AGZE out of a Levin half cut AE92. To convert it to RWD I have bought a T50 gearbox. Apparenly the flywheel from the AE92 will not fit the T50 gearbox.
    My question is, will a flywheel from a AE71 or AE86 fit.
    Peter
    Nathan
    Lilydale
    i would use a ae92 (smallport 4age) or ae101/111 20v 4age flywheel. as these are 112mm clutch size.
    better to have the larger surface area to help take the torque.
    hope this helps
    Last edited by Sprinter86; 19th February 2010 at 04:42 PM. Reason: was thinking of clutches, not flywheels oops - fixed
    Jonathan
    A 4A-C flywheel will not fit due to it having 6 holes instead of 8.
    Use any 4A-GE N/A flywheel.
    Senior Member resol's Avatar
    steve
    vic
    you have to change the spigot bearing aswell though dont you?
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Mark
    you have to install one. there won't be one in there. from memory its part number is 6001.
    Jonathan
    The spigot bearing is in the crank. It has nothing to do with the flywheel in these motors.
  1. CA Gearbox, T50 Gearbox, Ecu's,Exhaust QLD
    By damien454 in forum Car Parts For Sale
    Last Post: 23rd July 2012, 01:02 AM
  2. wtb- smallport flywheel (ae92) -adelaide
    By z250junker in forum Cars or Parts Wanted
    Last Post: 8th November 2011, 02:30 PM
  3. Ae92 Gearbox
    By Tbo92 in forum Car Parts For Sale
    Last Post: 3rd May 2010, 10:47 AM
  4. how much mm is the flywheel from a 4ac engine to a t50 gearbox
    By angelo in forum Technical - Questions
    Last Post: 10th June 2009, 11:59 PM
  5. stock ae92 4agze flywheel in t50
    Last Post: 23rd May 2008, 06:53 PM
