So no-one here has an aftermarket ECU? lol
If you have one, I just want to know if you went with coil packs or not and why?
I decided to get an aftermarket ECU for my car after massive fails with my standard wiring loom. I will be eventually going for quad thottles so its all good.
I was going to get a microtech but my tunner(mate) recommended a stinger 4424 ECU as I was going to keep it NA and it had better tunning capabilities vs the microtech.
I just have a question, would I need to convert to coilpacks or would the dizzy/coil work well enough? I have just seem everyone use coilpacks when getting an aftermarket ECU.
I have a Microtech LTX8 works well with stock coils on my GZE and i used the stock coil packs because they are easy to get hold of and not to expensive to replace.I think everyone uses stock coil packs for the same reason.
Hachiroku AE86 Masters Club S.A since 1998
I have cop on my adaptronic simply because it is neater. No coils, leads and igniters.
I have a Microtech ltx10s/X4 with 4agze coils for saleSetup for a 4agze but may work on an na engine as well.
