Results 1 to 6 of 6
Thread: timing light
    john
    nsw
    liverpool
    Default timing light
    hi guys .
    what should i look for or will any timing light do the trick . looking at spending 30-50max on it.
    not a whole lot of difference in them.
    i got one from repco i think, was like 50$.
    only complaint is the chassis on mine isnt the best, and the trigger has broken, so i need to depress the little switch with my finger.
    other than that it flashes good.
    try and get a smallish one, so you can monouver it into a good spot. mine is fairly chunky (gun type), and sometimes a bit hard to get into a good spot.
    - Blaise Pascal
    Kieran
    there isn't really much to them so pretty much any will do the trick
    I picked up my last one on hard rubbish and it works a treat
    Timmy D
    North
    i got one from a gaurage sale for 10 bucks and its still had the original case, destructions, and even the reciept for purchanse!!
    Mine has a dial on the back of gun that changes when the light flashes. so instead of trying to dial in for example 10 deg off the crank pulley, you dial in 10 deg on the dial on the gun and then set the crank pully to "0". Makes life a little easier, from a store this feature normally bumps up the price so may be alittle more pricey.
    you could always get a snap on one!! doubt it would be 50 bucks though mmmmmmm snap on
    JJ
    Thu
    Bankstown
    yo redsprinter,
    I need to do my timing as well because i took my dizzy out and i'm a moron/nub and didn't mark where the rotor was facing lol
    I'm getting one off my friend if you need to borrow it you're more than welcome to
    Dusty
    Lynbrook
    haha snap on ones are in the vicinity of $900
  1. AE86 Full Front Light/ Corner Light/ Grill Set
    By johnny_08 in forum Car Parts For Sale
    Last Post: 4th January 2012, 08:32 PM
  2. 20 valve timing cover spacer (middle timing cover, alloy plate)
    By KE70Man in forum Cars or Parts Wanted
    Last Post: 26th August 2011, 06:30 PM
  3. Timing Light
    By plohl in forum Brisbane & QLD Events and Discussion
    Last Post: 14th April 2011, 10:41 AM
  4. timing light
    By pen15 in forum Sydney & NSW Events and Discussion
    Last Post: 26th December 2010, 08:06 PM
  5. Anyone have a Timing light?
    By Low Style in forum General Topics (No Technical Questions)
    Last Post: 28th August 2009, 10:22 AM
