Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: rounded lug nut, and engine noise.
  1. #11
    Glenn ke_70's Avatar
    Clay
    Barossa!
    sure it isnt your timing belt loose or worn
  2. #12
    Senior Member racsov's Avatar
    Nick
    West
    bash a chisel onto the timing chain and weld it on there any good tyre shop should be able to remove it
  3. #13
    Mark
    timing belt has teeth so a) it doesn't slip unless its fucked and b) at that point your car stops working full stop.
    Much more likely to be a loose fan belt or alternator belt. but then again i doubt its a belt cos it would do it when you fired it up and stop after a bit.
    Take it to an exhaust place and ask them if they think its an exhaust leak
  4. #14
    Ade
    SYD, Inner west
    thanks for the replies fellas.
    he is a bit of a dick! he has destroyed pretty much every car he has own.
    -Eg Si wrote off, driving by himself on L's! ...dick
    -his sisters Eg banged up ever panel! ..again dick
    ..i saved the ae86...which he pervious owned....
    he bought it with moderate rust for 3400, i bought it stripped down off
    him in poorish state for 600.
    so besides that he is ok. haha
    as for the sound from the motor, it isn't any belts as i have checked and tightened them.
    the noise is a high pitched whistle....and it is coming from the motor.
    and i am not sure...but think it is been amplified through the oil breather.
    the noise only starts about 5mins after start up, when driving and the engine is warmest.
    hope that desciption helps.
    and as for the nuts i will have a go at them this weekend.
    AE86....robbing me! check the build.
    http://www.ae86drivingclub.com.au/fo...read.php?t=445
  5. #15
    Veteran blair's Avatar
    Blair
    SEQ
    vac leak?
  6. #16
    Ade
    SYD, Inner west
    could be, but i am running a weber. so there aren't many vac lines.
    i will check them.
  7. #17
    Aaron
    In the Mountains
    check that the lines are blocked off that are ment to be.
    i removed all the EG shit off of my motor when i put a weber on. its not needed and does nothing. i made up a small plate to permanatly blocked off the exhaust gas recirculation too altho it was long blocked up with carbon and gunk.
    if you ran it with low oil it could have started to wear something causing the noice. i used to run my 4ac low on oil all the time, it loved it, dry sump ftw. is your water pump leaking out of the little hole in the housing? could be that.
    do you have the timing cover fitted? could be just the normal operation noise of a old timing belt and you only just noticed it.
  1. Removing bastard lug nut
    By McLEVIN in forum Technical - Questions
    Last Post: 12th March 2012, 08:22 PM
  2. First engine start - Why does it make this noise!?
    By jet111 in forum Technical - Questions
    Last Post: 6th June 2011, 11:38 PM
  3. Getting off rounded bolts?
    By duurs in forum Technical - Questions
    Last Post: 10th November 2007, 09:53 AM
  4. weird engine noise! advice opinions please.
    By FKN16v in forum Technical - Questions
    Last Post: 5th June 2007, 10:20 PM
  5. knocking/ratteling noise from engine/gearbox..?
    By DRFT - 86 in forum Technical - Questions
    Last Post: 31st January 2007, 04:14 PM
