Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Brake pedal to the floor
    Senior Member Adsie's Avatar
    Adam
    Birkdale
    Default Brake pedal to the floor
    Car - AE86
    Motor - Blacktop 20V
    Use - Track
    Problem - Brake pedal to the floor
    Occurs/started when - After motorkhana run
    Personal situation - At the last motorkhana after each run (about 20-30 sec flat out 1st/2nd gear) when trying to stop the brake pedal would go straight to the floor. Anyone shed some light on whey this could be occuring? Car has front and rear JDM disks with all rubbers lines replaced with braided ones. Master cylinder was rebuilt about 2 years ago and you can pump up the pedal with the car off and it feels soild. So I am thinking it has something to do with the vaccum. On the blacktop one of the original vaccum lines for the booster is used and just ran a rubber hose from the front of the motor while the other one is blocked off.
    Thanks
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    sounds like master O ring may be gone?
    Adam
    Birkdale
    Thought if the master cylinder o ring was gone it would happen all the time? This seems to only happens after sustained
    high revs.
    Aaron
    nah your setup sounds ok. im running the same and its sweet. how long ago did you replace the hoses to braided.
    i always recommend replacing or rebuilding the master when changing to braided. the extra pressure that the braided hose holds usually ends up blowing out seals in the master causing it to bypass when pedal is applied.
    i dont think thats whats happening, the only thing i can think of is that you dont have the one way valve fitted or its the wrong way around
    Moderator Sam-Q's Avatar
    Endeavour Hills
    if you where running out of vacuum the pedal would be hard not sink down
    Adam
    Birkdale
    The braided hoses were done about 6 months ago. Is there a way to test the master cylinder besides what I have already tried? There is a one way valve fitted, will test that tomorrow make sure it's working.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    sorry if already said but does it only do it after long periods of heavy on and off braking, or all the time
    Adam
    Birkdale
    Pedal kind of always feels crappy but has only gone to the floor after a good thrashing. Like after a motorkhana run and once at the end of the straight at lakeside. So the brakes had time to cool when this occurred
    Dave
    yer i would still be looking at your master cylinder.
    my girlfriends car had a simliar problem, the brakes would work great most of the time, but every now and it would just go straight to the floor. turned out to be the mastercylinder
    this problem may be exadurated at a motorkhana since you are hitting the brakes harder and more often etc.
    and if your calipers/slave cydliners and all your lines arent leaking, then i dare say there isnt much else it can be.
    as stated the vacumme is only there to make it easier, your brakes should still work perfectly fine without the booster (just a tad harder to push..)
    - Blaise Pascal
    Michael
    Crimebrook 2749
    if it after a thrashing, why not try as a cheap option doing a full brake flush and using new fluid, as it might be boiling
    my bosses ute looses brakes after he thrashes when works turning to shit
  1. loss of brake pedal after drift
    By Bozu in forum Technical - Questions
    Last Post: 16th August 2011, 11:49 PM
  2. brake pedal slowly away when braking
    Last Post: 22nd November 2010, 10:23 PM
  3. Bad Brakes, pedal to the floor....and then car slows down
    By Blizzerd in forum Technical - Questions
    Last Post: 3rd February 2010, 10:57 AM
  4. ke70 clutch/brake pedal
    By slydar in forum Cars or Parts Wanted
    Last Post: 7th September 2008, 09:21 PM
  5. Brake/clutch pedal box
    By Blackers in forum Technical - Questions
    Last Post: 23rd August 2007, 02:14 PM
