Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 31
Thread: hydro handbrake help why doesnt it work like i expected
    Senior Member ae86-13b's Avatar
    Troy
    Gisborn
    Default hydro handbrake help why doesnt it work re desighned and works with ease
    hey guys here is a picture of my setup i mad.
    i have r31 diff with vs calipers.
    man i have to get 2 hands and tear this thing a new asshole to even make the car slow down. is it the pivet point of the brake do i need a longer handle.
    in the pic looks un finished but it is
    last post i re done the hole thing now with out trying brakes lock up, pics up
    It Aint A Motor If It Aint A Rotor.!!!!!!!!!!!!!!!!!!
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    that setup looks mad as (like simple and shit and easy to make) did you bleed it properly
    Nic
    Mt Evelyn
    Possibly have the lines the wrong way around. Get someone to pull it and check if the master cylinder level moves up. I know time in psi20v had this problem.
    Troy
    Gisborn
    hey guys i originaly had the lines the wrong way took it apart i pulled the handbreak and it pushed fluid outer the middle so go figure i mad that go to the rear brakes. and yeah it was simply and i knocked it up in 30min shame it dont work lol. on the hoist i spin wheels up and rip it it will stop the wheels its bleed perfect because my normal brakes work really good.
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    The reason it works shit is because como calipers have a large piston/bore size which requires more pressure on them for less clamping effect, running a smaller bore size mc will better the problem but changing to a smaller size caliper piston will make it work better.
    i have vs calipers with greenstuff pads in my ae86 3/4 mc and its rubbish, i now have a 5/8mc i will be installing.
    I hav ke70 front calipers in my ke70 old rubbish pads 5/8mc and its 5 times better than the sprinter.
    end result ke calipers smaller bore size more pressure for less force!!
    AE86 THE BEST
    Troy
    Gisborn
    yeah i have ur exact setup 3/4 mc with commo calipers. are there any other calipers we can use with smaller bore size feckkkkkkk!! does anybody no how psi20v used
    Troy
    Gisborn
    so is my desighn of the setup ok just wrong mc and calipers or should i creat a 1 metre stick to leaver it or is this no good
    Eddie
    sa
    you can always weld on a longer handle but that means it has to move further, just get killer brake pads and change to a 5//8mc or change back to 31 calipers and remove the manual adjuster mechanism, it worked for me for a few track days but im prety sure 31 have a smaler bore.
    AE86 THE BEST
    Troy
    Gisborn
    same problem with 31 calipers didnt really change when i changed calipers
    when i pull handbrake it barly moves the rod when it had no fluid in it it moved the rod all the way.
    Eddie
    sa
    it doesnt move much because you have sucha big mc bore pushing shtloads of fluid at once, the hb design looks not too bad, the best design has the mc link pin pivoting directly above the hb pivot point or just in front so that doesnt seem ur problem
    AE86 THE BEST
  1. Hydro Handbrake for a ke70
    By ke70 xx in forum Technical - Questions
    Last Post: 26th May 2011, 07:43 PM
  2. hydro handbrake $90
    By bones in forum Car Parts For Sale
    Last Post: 7th April 2011, 03:54 PM
  3. custom hydro handbrake
    By Nic19 in forum Car Parts For Sale
    Last Post: 14th April 2010, 08:55 PM
  4. WTB..hydro handbrake
    By sly1 in forum Cars or Parts Wanted
    Last Post: 9th January 2010, 12:29 PM
  5. G4 hydro handbrake
    By roger roger in forum Car Parts For Sale
    Last Post: 30th January 2008, 07:20 PM
