Car - ke70
motor - bigport 4age
use - grip and drift
problem - destroying vl presure pumps
occurs/started when - i got it back from teh auto electrician who rewired the whole car
personal situation - want this piece of shit running its doing my head in
as stated above since my car has been rewired it has been destroying the vl pressure pumps, the current setup is a vl in tank lifter feeding surge tank, then vl pressure pump.
at first i just thought i was getting unlucky with the pumps (2 second hand from wreakers) and bought a brand new one which then only lasted an hour. ive since taken the tanks out and flushed them, and voltage tested the pump which was getting 14 volts. is this to high?? i assume its only ment to get 12 volts, what could be causing this? as the auto elec is denying that it is his wiring which is the problem.
before there was two wires runing from the fuel relay to the pumps in the boot and the were wired seperatly and now there is one wire and they are linked in together. how have other people on here wired up your fuel setups? because this doesnt look right to me ???????
any help would be greatly appriciated
cheers mark
