Results 1 to 6 of 6
Thread: cutting front springs ke70
    alex
    Inner West Lad
    Default cutting front springs ke70
    how do you do it with a grinder without killing yourself?
    Glenn ke_70's Avatar
    Clay
    Barossa!
    by not using a 9''
    Moderator Sam-Q's Avatar
    Endeavour Hills
    you take them out of the strut first
    Dave
    i had a mate tell me how he did in back in NZ....
    you leave the springs in the front, and angle the angle grinder in such a way that when you cut through it both halves of the spring tend to spring away from the cutting disc
    its hard to explain, but once youve done one the "wrong way" you will understand.
    he also gave me such tips on how to shoot a top-hat at a wall with the force of the spring, by undoing the top nut in the top hat and getting your hand out of the way really quick.
    yer do what sam-Q suggests.
    - Blaise Pascal
    Veteran svenmate's Avatar
    Svenbot
    East
    1. Undo shock top while strut is in car. Use a rattle gun or a lot of muscle.
    2. Proceed to undo strut bolts from steering arm and strut top.
    3. Push down on control arm and yank bottom of strut out.
    4. The strut will fall off the steering arm and the spring will be loose. You do not need to use spring clamps or worry about getting shot in the head coz you undid the shock top. So when the strut comes out, the spring is loose and can't hit you in the face.
    5. Rotate the strut so the brake lines aren't being stretched and pull the spring out of the strut and then proceed to cut on a bench vice or something.
    I use this every time. When you put springs back in you dont need to clamp or worry coz they won't be fully captive or 'loaded'.
    Hope that helps.
    AE71 Build Thread
    Veteran Breaka's Avatar
    Matthew
    Pottsville
    Cut them while the spring is still sitting captive in the strut. Good times ahead.
    NOT. This is how I did my first lowering job. Not real smart.
    Do what svenmate said. Or purchase some spring compressors and whack them on the spring once the strut has been fully removed. Remove shock nut, slide the spring out and start cutting.
  1. *E7* Front guard cutting for castor
    By Shitbox in forum Technical - Questions
    Last Post: 25th January 2016, 10:40 PM
  2. Standard KE70 rear springs and AE86 front springs in SA
    By Seventy in forum Cars or Parts Wanted
    Last Post: 8th February 2012, 02:28 PM
  3. Replies: 1
    Last Post: 2nd July 2010, 01:10 AM
  4. Cutting Springs Tech
    By SON57A in forum Technical - Questions
    Last Post: 10th February 2008, 10:53 AM
  5. Cutting front strut for short stroke
    By callaghan86 in forum Technical - Questions
    Last Post: 1st February 2006, 08:25 AM
