nice little rig
Up for sale is my 1984 notchback gazelle,
im in Tassy but can drop off to the boat for interstate buyers
mod list:
inside:
cd player
300zx Z32 steering wheel
boost gauge
Monza 3-point harness (ADR approved)
engine:
CA18DET JDM
ACL Race series piston rings, rod-end bearings, 1.3mm metal head gasket
permaseal VRS kit
CA20E water pump
CA16DE timing belt
modified oil pump with oil feed restricter in head
tapped rods
S14 T28
exceedy super heavy duity organic clutch
front mounted intercooler
2.5in mandrel bent exaughst
poddy with hectikc cold air intake
Dr. Drift re-tuned ECU
surge tank
VL-turbo external fuel pump
new PBR clutch slave cyl
suspension:
S13 hubs, brakes and knuckles
S12 tie rod ends
R31 lower control arms and caster rods with R31 ball joints
S13 pro sport coilovers
adjustable camber tops
extended wheel studs on the front
EL Falcon rear short stroe heavy duty shocks
cut VN commodore wagon springs
The car gets along really really well.
Runs 14psi on a safe tune, has room for more
I am looking for a standard car now so i would like this gone.
Price $4000
pm or msg 0438 699 365
Will swap
nice little rig
very good set up for the price. much better value than most ae86's in terms of mods for your money.
best of luck with the sale, although you really shouldnt need it.![]()
Cheers guys, Gets along well
what sort of power..150rwkw?
It had 160rwkw before the rebuild
if this is the car, which it definantly looks it. Ive seen vids of it. Sounds tuff and looks like it goes hard.
