Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 37
Thread: weird annoying ticking noise
    Senior Member .ady's Avatar
    Andy
    Footscray
    Default weird annoying ticking noise
    hey guys jst got home from some spirited driving. on the way home i noticed a weird ticking noise from inside the car. at first i thought it was the gearbox area but the noise is coming from the passenger side where the glove box is.
    i popped the bonnet and there is a ticking noise around the injector area. the noise is progressive so has the rev gains the noise and speed of the ticking does also. its really weird never had this noise b4
    its really annoying anyone have any idea wot it is?
    edit: video!
    you can hear the ticking noise towards the end of it around 1.30 onwards.sounds like a lawn mower or someshit to try and describe it. you can hear me feather/play with the throttle and you can make out the ticking noise along with engine sound, diff whine and my gay gear box.
    comment!
    Site Supporter Javal's Avatar
    Josho
    Gonna need to put a video of that shit up bro, or get someone to look at it IRL.
    Things like this are hard to accurately diagnose on 'teh interweb'
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    injector pulse
    Josho
    Injector opening / closing does not get louder after a drive.
    /yourtheory
    p.s. I am going to be all over this thread for the next few hours in an effort to stamp out all the mechanical hearsay that is very commonly associated with threads like this one. Usually this results in you throwing parts at the car until it gets fixed or you take it to a mechanic.
    Andy
    Footscray
    ill see if i can get video going soon theres alot of other shit going on in the car so its hard to jst pin point the noise in the video but ill try my best to get it. not sure if this helps but my fuel light started to flicker on and off as i was sliding i was low on petrol but not that low could this hav any contribution?
    Josho
    Not really.
    Fill the blanks here -
    Is the noise there / better / worse
    Engine cold / hot
    Does it worsen under load
    Are there any conditions under which the noise changes / fluctuates
    Andy
    Footscray
    engine warm
    start to notice it after certain rpm
    noise is there you can clearly hear it at a low rev and high gear - jst like u hear ur diff but instead of that a ticking noise
    higher u go thru the revs the more u can hear it and the faster it sounds not sure if it gets louder but u can certainly hear it with gearbox rattle and 4age roaring at 5-6k rpms
    Josho
    Sounds like a tough one man.
    Gonna have to get that video up or get a competent mechanic to look at it IRL.
    Jay
    it sounds like the valve/lifters are ticking which is a common problem when the oil your using is to thin or it is getting to hot after spirited drives
    nulon do an engine additive which will fix it up or you can just use a different oil which is a little thicker to stop it
    Rust is a way of life
    Veteran Rice86's Avatar
    Richard
    Liverpool
    yup sounds like ur discribing lifter noise, a lot of other cars have this sound aswell,second hand mostly, ive went to have a look at a S15 for a friend and got the lifters on idal was amazingly loud,...tick tick tick tick tick tick i was waiting for the BOOM...
    dose
  1. weird noise in a 4age
    By wanted_ae86 in forum Technical - Questions
    Last Post: 5th September 2011, 11:05 PM
  2. 4AGE hesitation and weird induction noise - HELP
    By barbel in forum Technical - Questions
    Last Post: 26th July 2010, 07:41 PM
  3. weird noise
    By michaeltay31 in forum Technical - Questions
    Last Post: 7th February 2010, 09:57 PM
  4. 4age - ticking noise
    By pogi in forum Technical - Questions
    Last Post: 13th July 2009, 03:17 PM
  5. weird engine noise! advice opinions please.
    By FKN16v in forum Technical - Questions
    Last Post: 5th June 2007, 10:20 PM
