Results 1 to 8 of 8
Thread: 7AGE Fuel/wiring issue?
    E-Famous (Remeber your roots)
    Thumbs down 7AGE Fuel/wiring issue?
    Car:
    Motor -
    Use:
    Problem:
    Any help will be greatly appreciated.
    Love marvis.
    Anthony
    Should only prime with the key to IGN, not ACC. But anyway, what you need to check si whether the relay clicks every time but the pump doesnt whirr every time, or whether the CO relay only clicks 2/5 times and the pump whirrs every time the relay is heard clicking.
    That will tell you whether it's a wiring issue in the key barrel/main power area or whether its a pump or at least wiring to the pump issue.
    It is IGN sorry, the one before you start it
    Relay click? CO relay?
    I am new to this, ESP wiring.
    Senior Member 08ftwyo's Avatar
    Tim
    Milton
    Relay looks like this, when you switch the ignition on, you will feel it click or something.
    Offtopic, how does the 7a go with adaptronic?
    Daniel
    GC Hinterland
    What are your prime time and trigger timout in the special function tab of warv? How is the engine wired? with a factory setup or a 'custom' loom?
    SHIT atm. 66kw. Something is up LOL.
    Ant and signature did it, so I have no idea. Custom loom.
    Anthony
    CO Relay is Circuit opening relay. The name toyota gives to the fuel pump relay. The prime and timeout settings should be 3000ms and 300ms respectively, so everytime you turn the ignition on, you should hear the pump for 3 seconds and the hear the relay click off again. Once you have located it (it should be in the dash/cabin area somewhere) just check it for consistent operation as above.
    Hole in the fuel filter
    LOL LOL
    Also alternator is dead...
  1. 7AGE - Revving, electrical or vacumm Issue
    By Lunatik in forum Technical - Questions
    Last Post: 27th January 2012, 05:41 PM
  2. 7AGE Issue?
    By marvis in forum Technical - Questions
    Last Post: 12th August 2010, 06:55 PM
  3. Headlight wiring issue
    By barnzy - ksev in forum Technical - Questions
    Last Post: 5th May 2010, 09:34 PM
  4. lights wiring issue
    By ke70astro in forum Technical - Questions
    Last Post: 2nd August 2009, 11:10 PM
  5. wiring loom issue
    By sik-86 in forum Technical - Questions
    Last Post: 13th May 2007, 10:56 AM
