CO Relay is Circuit opening relay. The name toyota gives to the fuel pump relay. The prime and timeout settings should be 3000ms and 300ms respectively, so everytime you turn the ignition on, you should hear the pump for 3 seconds and the hear the relay click off again. Once you have located it (it should be in the dash/cabin area somewhere) just check it for consistent operation as above.
