Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 31
Thread: wheel stuck on hub
    Member richo's Avatar
    Matthew
    Capalaba
    Default wheel stuck on hub
    this happened to me the other day when i tried taking my wheel off and thought i would post up.
    took off the wheel nuts, which werent on too tight but the wheel wouldnt come off. tried pulling and pushing, ended up getting a sledge and crow bar out but still wouldnt come off.
    in the end i got out the ol grinder and drinded a small nick on the side of the center of the rim and started levering it off. took me a good half an hour after everything. luckily it was a cheap $10 wheel which i think suited a fiasta.
    has anyone else come across anything like this?...
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    YUP.. I've had this happen..
    It look from that photo thet the spigot park of the hub...The bit which the wheel locates on is just got a lottle too rusty... Some cars their is very little clearence between the wheel center and the hub..
    I've seen wheels get stuck on just from a coat of paint... also from trying to take them off while hot... Never to the extremes of having to grind them though... Always been abit of movement so I could wiggle them off.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    jack the car up (DER) and if you can get under it (laying down) and kick the fucker off
    Matthew
    Capalaba
    had it up on stands and was under hitting the shit out of it. had two people trying but still wouldnt. had only been on for week.
    Mark
    Yeah and once the paramedics are finished using the jaws of life to get the car off you crushed and mangled body you might be able to borrow them to get the wheel off!
    Michael
    Crimebrook 2749
    if you cant put a car on stand properly thats your issue
    ill just never work on a car again then......
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    yeah, best thing to do is sand all the rust of the locating hub and stick some grease on it when the wheel goes back on
    ~KEEP DRIFTING FUN~
    Site Supporter Javal's Avatar
    Josho
    Center hub hole would have been fractionally (~1mm) too small for the locating stub on the axle. You wouldn't have had a problem winding it on with the wheelnuts but getting it off would be a cunt.
    Just a guess, but it's likely to be what happened, especially considering the wheel is for a fiesta.
    Jason
    Nundah
    Was it a factory wheel fot your car.??? I know some cars are only very slightly different in the Inside Diameter.. off buy only .5 of a mm or so..
  1. hub stuck to my rotor !!
    By toddheart86 in forum Technical - Questions
    Last Post: 16th October 2011, 10:45 PM
  2. Wheel Stuck on KE70
    By ke70 xx in forum Technical - Questions
    Last Post: 29th April 2010, 04:29 PM
  3. WTB wheel cap/hub thingys
    By RolandGTV85 in forum Cars or Parts Wanted
    Last Post: 24th August 2009, 05:49 PM
  4. wheel stuck to hub
    By KKUSTOM in forum Technical - Questions
    Last Post: 5th July 2009, 05:32 PM
  5. Taking Off Wheel hub/studs
    By KR.JO in forum Technical - Questions
    Last Post: 25th June 2007, 05:25 PM
