Results 1 to 4 of 4
Thread: 4agze ecu
    Senior Member Stej's Avatar
    Steve
    Default 4agze ecu
    Hey Iam currently doing a turbo conversion on my GZE. Ive been told that using a standard GZE ecu with a SAFC2 wont work, because of ignition and timing problems? Ive just been reading on some of the threads and many of you guys are running stock gze ecus fine with a turbo setup.
    Reeece
    Casula
    It works fine, used the stock gze Ecu with 13 psi on a ae92 afm setup for years. Runs abit boggish down low due to over fueling but as revs go up leans out and rips hard.
    Restricted to around 140-150 kw due to afm or ae101 boost cut on Ecu , afm doesn't have the boost cut so it's more workable. It's good enuff but nothing beats standalone on a 4agte
    Steve
    Yer iam running a late model 4agze which is map sensored. I think the ecu is restricted to 14 psi? I only plan on running about 12 psi.
    Reeece
    Casula
    Yer boost cut is around 14 psi , usually when you turbo the ae101 you don't suffer from engine knock as the sc12 is removed, like I said the only problem is the ecu over fuels at low rpms other then that the Ecu gives awesome a/f and idles better then a factory 4a
  1. 4agze ae101 ecu and bigport ecu.
    By 86TRD in forum Car Parts For Sale
    Last Post: 4th April 2010, 07:07 PM
  2. Replies: 15
    Last Post: 22nd December 2009, 05:48 AM
  3. ae101 4agze loom/ecu onto ae92 4agze?
    By 84ae86coupe in forum Technical - Questions
    Last Post: 16th May 2008, 01:30 PM
  4. CAN 4AGZE ECU RUN ANY 4AGZE ENGINE?
    By HYPNTK in forum Technical - Questions
    Last Post: 8th November 2006, 11:20 PM
