Results 1 to 10 of 54
Thread: Tys Ae71
    Mar 2010
    Ty
    Western
    Default Tys Ae71
    So heres the deal
    -Bought this car Stickered, Out of rego but it had a running 4age with a few dodgey minor problems.
    -Problems, When i got it, I had a mate pick it up for me and he told me about the brakes not really working and he had to use to hand brake to stop. lol
    So once i got it home i took the brakes apart and found out i had ceized front calipers.
    It also had a dry brake system with no brake fluid at all.
    - The input of the engine is done nice and clean but theres alot of dodgey wiring, For example i have speaker cable running to the alenator just waiting to be shorted out.
    -My earth key isolation switch is running from the positive lead instead of the negative lead.
    -The Surge tank is a full born cut and shut job.
    Most things on the car so far are done well but other things it looks like theyve just cut corners.
    There all a easy fix so i dont mind.
    -Ive gotten rid of the old clutch fan and have mounted up a single thermo fan for the time bein.
    When i find a matching thermo fan ill go twin but the single good enough for now.
    Fixed a small waterleak from the by pass valve on the water pump housing.( gotta love cilicone).
    Replaced the front calipers and bled the whole system now its sweet as.
    Just started measuring up templates to fit in my centre of my dash(next to the speedo)
    Im putting a button start there along with a fuel pump switch and manuel thermo fan switch and temp gauge with a warning light telling me when to turn on and turn off.
    Anyways..
    Its a 1984 Toyota corolla Ae71
    Engine: 4AGE, Not too sure what type though.
    4 to 1 extractor with 2 1/2 all the way through to a small cannon
    Electronic thermo fan
    Pod filter uleh
    Driveline:T50 gear box
    T50 tail shaft to borgy
    Suspension: Front, Stock cut Coils
    Rear, Cut AU falcon springs
    Other: Locked diff
    Heavy duty clutch
    Ma61's 14x7 not sure on the spec
    14x7 Wantanabes looking things lol
    30mm bolt on spacers on the front
    Luisi mirage corsa deep dish steering wheel
    Fenders
    To come:8kg front springs
    6kg rear springs
    Excel g short stroke inserts(This friday)
    Corona xt130 LCA
    Lock spacer
    Front strut Brace
    Sway bars
    Velvo milano bucket and harness
    Ill try and keep you all updated with lots of pictures and lots of information.
    Feel free to leave your comment and hand me some advice.
    Cheers Ty
    Will get some pictures up asap.
    Veteran svenmate's Avatar
    Svenbot
    East
    Such a bandit car. Lol. Need pictures in here.
    AE71 Build Thread
    Mar 2010
    Ty
    Western
    The The cardboard in these picture is just showing where im sheet metal for my switches an earth key, And the picture of the water pump housing is where i had the leak from
    I stripped it all out and the pictures from it sittin on its feet is pretty much how i bought it.
    Senior Member Brendan's Avatar
    Brendan
    nice fer jripht?
    Mar 2010
    Ty
    Western
    Got Myself a couple shims so i finally got this beast in.
    Now just to fix a tiny water leak a remount/wire a battery and i should be all good for mallala on the 27th.
    Sherlock
    Yew! Good to see progress. Nice wipers
    Mar 2010
    Ty
    Western
    Knew you'd like them sherlock lol. Waiting on my rear short stroke shocks and i should be putting them in tonight.
    Veteran shift_rook's Avatar
    SE Burbs
    nice buy dud! looks great
    Nov 2009
    Eastern Suburbs
    yeah man sick buy! saved your self a lot of coin. picked up my 4a today cant wait to get it in and get back down there and do some skids. ill be watching out for this on the 27th
    Mar 2010
    Ty
    Western
    Cheers ... Pretty happy with the buy. Ive had to spend money but im still kinda ahead.
    Got fucked around with the rear inserts went to meet this bloke and he wouldnt answer or return my messages. Finally took this for a drive 1st and 2nd gear snakeyss. Soo good im overly excited for mallala now hah willkeep yall updated.
  1. Replies: 4
    Last Post: 26th July 2011, 02:30 PM
  2. WTB: Adelaide - AE71 pedal box, AE71 tail shaft
    By AJPS in forum Cars or Parts Wanted
    Last Post: 19th April 2011, 05:55 PM
  3. WTB: ae71 tailshaft & ae71\ae86 radiator [VIC]
    By timos in forum Cars or Parts Wanted
    Last Post: 13th July 2010, 07:00 PM
  4. WTB: ae71 front doors + wagon tailgate to suit ae71 or ke70
    By 82rollawags in forum Cars or Parts Wanted
    Last Post: 23rd June 2008, 10:52 PM
  5. ae71 pedal box and ae71 engine Xmember (SA olny)
    By KE_sev in forum Car Parts For Sale
    Last Post: 19th May 2008, 01:26 AM
