Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 35 of 35
Thread: 16v head on 20v block
  1. #31
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Sprinterman knows his shit, and if you ask the right questions you'll get the right answer, top bloke...i mean over 15years with AE86 and 4ages and other #AGE combination in experience, to say he doesn't know shit is pretty bald specially when you have not meet or dealt with him..if that is the case.. have you seen the blood red Trueno his building for his mate sitting in his garage, just the brake setup alone, Brembo off Evo7 i think is the brake setup..most people arent even confident of changing ADM brakes to standard JDm brakes =.='.. no N2 spec but its top quality as a N2, and have you ever seen HIS AE86?...last time ive herd of it was 200kw at the wheels on 20v turbo just sitting in his garage collecting dust cause his to busy fixing everyone else AE86..
    off topic sorry
    dose
  2. #32
    Jul 2010
    huh ^lol
  3. #33
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    Blair, did you find that everything bolted up fine? What HG did you use? Were there any other problems?
    quit hatin get bakin!
  4. #34
    Veteran blair's Avatar
    Blair
    SEQ
    Only thing that doesnt bolt up properly are the supports on the rear of the motor (brace the motor to gbox? cant remember...) but meh.
    Everything else is the same. Used 16v Gasket as everyone i speak to sais to use the one for the HEAD.
    No problems man... other thing to note is i have carbs so can adjust accordingly... i'm not sure how a stock bigport ecu would go with the extra compression etc? (anyone running this setup?)
    The way i saw it was if i'm gonna spend the $$ on a rebuild.. may aswel spend a couple hundred more and start with a higher compression/7rib/better base
  5. #35
    Joe
    NT
    Nightcliff
    I am surprised that this isn't more common if it was that easy! Thanks for the info. I will definately be doing this with my next bigport. Maybe even go carbs as well.
  1. Replies: 0
    Last Post: 19th May 2011, 09:40 PM
  2. 4AGE head 16V + Block TAS
    By Prewer in forum Car Parts For Sale
    Last Post: 31st July 2010, 07:43 PM
  3. Replies: 9
    Last Post: 23rd June 2008, 08:23 PM
  4. 16V head on 20V ST block
    By naksutaung in forum Technical - Questions
    Last Post: 22nd March 2007, 10:45 AM
