You can take a fair amount off it and still be "safe" eg none interferance... just depends or what CR you want when your finished..
what i would like to know is how much can/should i get shaved off my head
reasons;
1. what the surface flat
2. up the CR a little
but i want it to be all safe and non interferance
~KEEP DRIFTING FUN~
well wats a popular option as im open, i.e rebuilt 4age looking for some more power out of it
~KEEP DRIFTING FUN~
From memory I went: 10thou off the block and 30 thou off the head and used a stock head gasket for 10.7cr roughly...???
If you've got the head off get a good valve job done... Will net you good results and shouldn't cost too much..
which 4age are we talking here
Mine was a Bigport.. so the gay comp ratio to start with...![]()
what he said, plus 0.8mm or 0.5mm headgasket (depending on what u want)
well according to my chart your compression ratio goes to 9.7:1 with a 0.8mm gasket. Whatever you do this is a good choice as it closes up your piston to deck clearence. From there I would personally take another 0.5mm off or there abouts. I can work out what that roughly will get you in the end.
hmm interesting. im thinking about doing the same with my smallport and using a 0.5mm headgasket. is there a formula for working this out, say 0.5mm gasket and 0.5mm off the head on a smallport?
there is something, however when shaving heads it's not tottaly linear in the rate of change
I don't go near 0.5mm gaskets because I still can't figure out how the pistons don't hit the heads
