Results 11 to 20 of 21
Thread: Interchangeable Parts for AE86, and similar models.
  1. #11
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Headlight glass: the ae82 glass is a direct replacement for the 86 glass
    Wheel studs: Varius other shock absorbers are avialable for other models that have different lengths, for more information please visit this link: Interchangable wheel studs
    Seats: AW11 MR2 seats are a direct bolt in and ae71 seats are a very close fit and can be used.
    Door locks: Daihatsu charade (84ish model) door locks are exactly the same as sprinter ones
    Strut tops: The strut tops of a KE70 strut tops bolt into an AE86 and give you more caster
    Headlight lenses: 180, mr2 & trueno hav the same headlight lens as do RA60/st162 celicas
    Light switch: the ae86 light switch is the same as Ford EA falcon
    Front wheel bearings: ae92 rear bearings may fit AE86 front bearings.
    Front shock absorbers: Varius other shock absorbers are avialable for other models that have different lengths and valving, for more information please visit this link: Front suspension options
    Rear shock absorbers: Varius other shock absorbers are avialable for other models that have different lengths and valving, for more information please visit this link: Rear suspension options
    Rear Springs: XD to XF series falcon rear springs can be cut down to suit the rear on ae86's, 2.5 coils cut off is a good ride hight. siffens the rear to approx 6kg/mm
    Suspension arms: The SV21 and other Camrys have adjustable rear arms that can be used for conversions. (Weld the adjusting part into another suspension arm).
    Cylinder heads: Twin cam 16v GE heads will bolt onto a 4ac but will drop the compression very low (i think 6:1), but i could be possible to deck the head enough to raise the compression or just get some GE pistons. One of my mates has made 110rwhp reliably using this set-up and twin solex carbs.
    Boss kits: AE82 boss kits fit ae86's
    Alternator brackets: The bracket off a 4afe for the alternator will bolt striaght onto other 4A based blocks
    Alternators: The alternator off a Celica st185 fits perfectly for a 4age, and can deliver 20 amps more current.
    Bonnet hinges: ae82 and ae86 bonnet hinges are identical
    Bellhousings: JDM 4AGE bellhousing are a direct fit in place of an Australian T50, however the slave cylender is on the drivers side instead of the passeneger side, an RA60 solid clutch line and T18 Clutch slave is an exact fit to suit the change of side.
    Assorted extras: RA60 celica - rear hatch struts, number plate lights, windscreen washer pump & bracket and rear seat release knobs are all compatable with a sprinter
    Steering racks: AW11 and AE86 manual steering racks are identical
    Heater: The interior heater box, fan assembly, and A/C units are all identical or interchangable between AE86, TE71 and KE70. The heater core of the TE71 has one outlet pointing the other way, which can be fixed. The non-A/C air duct from a KE70 can be used to convert a AE86 back to non-A/C.
  2. #12
    Mar 2010
    Luke
    MELBORUNE
    +++ Rep to Sam-Q. Now thats, what Im talking 'bout!
    Much appreciated!
  3. #13
    gay
    n1gger land
    n1gger land
    south korea seoul
    i own both an AW11 and an AE86 and i can confirm aw11 seats and ae86 seats are NOT directly interchangable.
    the driver side seat, right hand side rail sits slightly out and can not be bolted, you need to make a way of spacing it.
    i adapted a recaro on ae86 rails to fit in my aw11. sits very nicely and gave a perfect driving position, but needed work to be able to bolt at all 4 mounting points.
  4. #14
    Mt Macedon
    Some leads to give an idea for more searching:
    - RA40 strut legs fit (may have an issue fitting the big spring and top hat in the strut tower). Gives the bigger stub axle and a good base for sutom brake upgrades
    - XT130 strut leg and hub, RA60 disc, MX62 caliper (with a little machining), AE86 top spring perch and custom spring gives you a good, ventilated brake upgrade
    - XT130 strut, Peugot disc, Hilux 4 pot calipers is a classic conversion. Again need to sort something with the spring.
    - XT130 (and many others) have a lower control arm 10mm longer than AE86. Gives about 1 degree neg camber.
    - RA40 tie rod tubes and tie rod ends allow for extra adjustment if you widen your track.
    - ST141 discs bolt up to many drum braked diffs with a few mods (S, T, E and some F series).
    - AE82 steering wheel fits for a nice, factory looking swap.
    - T18 diff bolts in (if you can find one nowadays) with T18 rear section of the tailshaft. Takes any T series centre.
    - RA40 diffs have been rumoured to have been fitted. A little more work involved.
    - AE71 gearbox is the same T50. Most people know this nowadays, so you're unlikely to stumble over a bargain any more.
    - Many radiators and thermos fit with minimal work (V6 camry??, ST162, some old Excel??)
    - R32 non-ABS, S14??, some old Corona, widebody Camry??, and more brake master cylinders fit if an upgrade is needed.
    - MA61 seats are rumoured to fit.
    Note, if I mention it's rumoured, or there's question marks beside it I haven't personally tried it, but have heard it discussed. The rest I've tried first hand.
  5. #15
    Jay
    Ive tried MA61 on the passengers side and it wouldn't fit straight in but 3 of the 4 bolts lined up just would have needed a bracket extended on the last one
    Rust is a way of life
  6. #16
    Coolangatta
    Confirmed. Parrot originally did this and Hen welded in the mounts (2 x ST162 bolt on mounts) for the one currently sitting in my sprinter.
  7. #17
    gay
    n1gger land
    n1gger land
    south korea seoul
    V6 camry throttlebody is a nice upgrade for a 4age also.... i had a spare one sitting around so i bolted it onto my smallport.
  8. #18
    Reeece
    Casula
    Any more info on this? Tps work,size,model year of camry
  9. #19
    Junior Member -nfi-'s Avatar
    also keen on throttle body info...
    so im guessing its bigger than 55mm??
  10. #20
    Adan
    Oxley Park
    also sw20 mr2 seats fit fairly easily.
    Just need to widen the 2 rear holes slightly and use the standardpacker to make it sit level.
  1. does anyone know the diffrence in the ae86 models and years
    By enzo in forum General Topics (No Technical Questions)
    Last Post: 2nd May 2012, 02:05 AM
  2. Japanese Ae86 Models & Figures
    By Teddy in forum Other Items for Sale
    Last Post: 20th March 2011, 12:25 AM
  3. interchangeable parts
    By h i t o r i k o in forum Technical - Questions
    Last Post: 18th August 2008, 04:22 PM
  4. you like ae86 models?
    By ae86hachiroku in forum Toyotas in the Media
    Last Post: 2nd September 2007, 10:56 PM
