Results 1 to 10 of 48
Thread: DR86FT My Sprintang
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Thumbs up DR86FT My Sprintang
    Hey my name is Kaan I've owned this sprinter for about 6 years. Now I'm trying to fix it up so it lasts a bit longer. I went through cancer last year and I'm ok now. But now the problem is i wanna save my sprinter from cancer. I dont have much money and dont know much about repairing rust etc. So if you wanna help let me know. Also I am looking for more pics of my car if you have any my number plates were NSW : DR86FT or SA : DORI KIN.
    I am currently building a GZE bottom end and Big Port head Turbo engine. So I need the car not to fall apart when I drive it lol.
    Here she is....
ID:	9283   Click image for larger version.
ID:	9284   Click image for larger version.
ID:	9285   Click image for larger version.
    Senior Member mals86's Avatar
    MAL
    Cairns
    Hey bud, as far as the rust goes, just make sure to strip every panel down to make sure there is no sneaky shit hiding in behind the seals etc.
    depending on the severity of the rust (show some pics of it) you may want to break out a mig welder and slowly teach yourself how to weld.
    Grind back any shitty bits and replace with fresh steel (I found getting old bonnets from a wreaker to be fairly cheap).
    Also google 'automotive rust repair' there is heaps of info to guide you as well. Only use bog as a final touch up to bring back the shape above the freshly welded steel. Im still not the best at rust repair, but check my build thread if you want to see some massive rust repair (on the 2nd car).
    Being able to confidently weld is important, im still learning myself. Good luck with it and remember to replace panels with better ones if possible, it will save time and headaches.
    Senior Member sotiros86's Avatar
    Andrew
    Wollongong
    Hey mate, do you live in Wollongong? Cause i have a feeling that i use to see this car getting around there a couple of years ago.
    If you are, there are quiet a few AE86 guys floating around Wollongong (myself included) who would be happy to lend a hand if you need it
    Kaan
    Emerald
    Yeh I live in wollongong/oak flats. I never see any. Only a red one and my sis spotted NAV-086. well i would love for u guys to help if u could be bothered. cheers
    I will look at your build thread and google it.. I'm not real confident still. would fibre glassing be a good fix?
    Thanks mals86 & sotiros
    Kaan
    Emerald
    UPDATE: Just organizing the engine etc
    Smallport 4agze block with squirters
    ae92 bigport head
    rwd inlet etc
    gze injectors also have some rx7 ones just in case
    cams undecided maybe toda 264 or dunno
    turbo thinking a disco potato
    gonna buy a kelway turbo manifold
    exhaust is later
    need to work out what to do about gearbox
    If anyone has tips about 4agte build let me know
    KB
    Senior Member Mr Awsome's Avatar
    Dave
    Plympton
    arrrrrrhhh i remember blowing the diff in this bad boy. those where the days.
    Kaan
    Emerald
    yeh just before we had to go out lol good times
    Senior Member Arch's Avatar
    St Agnes
    i remember when we locked the keys in it and had to find a way in ahhaahah
    ahh the good old days, i miss them badly. will catch up with you next time i come to adelaide kaan, hopefully in my new car
    Kaan
    Emerald
    UPDATE: Building Engine and putting together gearbox and also sent the car off for body work
    Kaan
    Emerald
    Default Updates
    Update: Still building the motor but have had progress.
    Moved to Emerald QLD not the best place to source parts from.
    Have spent lots of Money and still spending.. its never ending
    Here's some pics constantly working on it so will take more in a couple weeks
ID:	20260Click image for larger version.
ID:	20273Click image for larger version.
ID:	20272Click image for larger version.
ID:	20271Click image for larger version.
ID:	20270Click image for larger version.
ID:	20269Click image for larger version.
ID:	20268Click image for larger version.
ID:	20267Click image for larger version.
ID:	20266Click image for larger version.
ID:	20265Click image for larger version.
ID:	20264Click image for larger version.
ID:	20263Click image for larger version.
ID:	20261Click image for larger version.
ID:	20262Click image for larger version.
    Currently putting the diff together. F series yr22 4.1 ratio TRD 2 way just need to adapt the handbrake cables.
  1. Do You Own A Sprintang . . . ?
    By JohnnyAe86 in forum General Topics (No Technical Questions)
    Last Post: 27th October 2007, 10:37 AM
