Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: Elliot Design Tacho's
    Jul 2009
    Daniel
    Morisset
    Default Elliot Design Tacho's
    ORDERING SOON! Orders to be in before July so we can order in July!
    Ok so you've just put a new engine into your car... but it revs higher than the tacho says. so to avoid over reving your gonna install a new tacho ... but your only options are SuperCheapAuto ones or whatever the local auto shop has ... now we all know that these are not the best things in the world and when you put one in your car they stick out like dogs balls because they light up blue or red and are all shiny silver ... but i now have a solution to this...
    introducing the Elliot Design LC 80L and LC 100L
    these are made in England and have been used in motorsport in the UK for years
    they are a light weight tacho designed for race & street modified engines and that means they have a high RPM on them... so yes i can get you a tacho that reads 12,000RPM hell if you like i can get you one that reads 18,000 RPM but we all know we aren't gonna need one that high.
    anyway there's a few designs to choose from.
    Black Face
    White Face
    Custom designs
    12,000RPM
    Back view
    these are just a few samples of the work that can be done, they can incorporate any logo, style or colours into your tacho
    heres the spec's
    * 80 and 100mm diameters.
    * Flood illumination with external lamp holder.
    * Black or white dial faces.
    * Very compact ( only 45mm deep ).
    * 200mm long flying leads for easy installation.
    * Very lightweight ( LC 80L weighs only 250 grams ).
    * Std scales for LC 80L 0-8. 0-10. 0-12. 0-14. 0-16. & 0-18. Krpm.
    * Std scales for LC 100L 0-8. 0-10. & 0-12. Krpm.
    * Cylinder configuration 2.4.6.8.& 12 cylinder engines
    * Accuracy tolerance 1-50rpm
    These are compatible with manufacturers’ original equipment, and after market ignition systems, including contact breaker systems.
    Mounting brackets are also available.
    i have organized a deal with Elliot Design and they are willing to cut some price for us, so the more we can order the cheaper it is.
    5+ orders = $245
    10+ orders = $225
    15+ orders = $205
    these prices include shipping straight to your door.
    Prices are based on current money exchange rates and cost may slightly change.
    Custom designs may also attract a higher price.
    ORDERS.
    1. Faceplant456 X1 LC 80L BF 12.5k Rpm
    2. starni_boy X1 LC 80L BF
    3. (you) ?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I am interested due to how bad the stock tacho is out.
    but I am unsure how you will go trying to sell them here, I suspect poorly due people many people being tight arses unless you bolt a dished wheel to this gauge.
    I will not have a look at how I would go installing this into my facia, looks like if I got one the oil pressure sendor would have to go.
    now got a side view?
    what about specifications on accuracy tollerance?
    Jul 2009
    Daniel
    Morisset
    edited first post to include these.
    Glenn ke_70's Avatar
    Clay
    Barossa!
    do they do other guages?
    Veteran AJPS's Avatar
    Lonsdale
    they look good
    Jay
    very simple and effective design , very similar to Omori gauges
    Rust is a way of life
    Jul 2009
    Daniel
    Morisset
    just mount it takumi style
    as for other gauges i think they only do tacho's but if they really wanted to i think they could do a range of gauges, but they have done just tacho's for years so they gotta be doing something right.
Name:	takumi tacho..jpg
    Endeavour Hills
    no thanks I like the stock look
    Senior Member Blizzerd's Avatar
    Mike
    Thornlie
    i would be interested in one, can we get custom design ones? maybe have ae86 logo on it.....
    Jul 2009
    Daniel
    Morisset
    yes we can get custom designs, on the ones pictured above where the elliot design logo is we could replace that with anything ... even the AE86DC logo .
    then you can also choose the colours for the dials and outer edge.
  1. elliot's corolla
    By -elliot- in forum KE70 / AE71 Owners Forums
    Last Post: 29th June 2010, 12:41 AM
  2. Panda Design & Photography
    By The Human Panda in forum Photography & Digital Design
    Last Post: 25th February 2010, 07:45 AM
  3. New tire design by Michelin
    By SR20_AE86 in forum General Topics (No Technical Questions)
    Last Post: 6th January 2007, 09:44 AM
  4. ae86 design
    By Gavin in forum General Topics (No Technical Questions)
    Last Post: 1st December 2006, 06:36 PM
