Results 1 to 10 of 50
Thread: High revving BT 20v???
    Senior Member slideways's Avatar
    Tristan
    Thumbs up High revving BT 20v???
    The objective is to build a BT 20v that can rev to around 9000/9500 Rpm.
    Bottom end will be standard crank with the usual strengthening and balancing treatment, good bearings, forged and balanced rod/piston combo.
    What C/R is good for this
    What cams would I be looking at to make power with these revs,
    What valve train mods should be looked at with said cams?
    Are there any uprated oil pumps available of the shelf?
    Do you retain the vvti?
    Do the T3 velocity stack hit the brake booster in an AE86?
    Best Ecu option for a 20v?
    Also has anyone got any build info on Sexy16's 10,000 rpm coupe?
    And yes have searched a shirt load, and their is no definitive information.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    you can forget the standard rods no matter what you do to them. Get spool or something
    The 20V is a simple engine most ecu's will be fine, Wolf usually has issues though.
    You can shim the stock oil pump for more pressure.
    Stock pistons are fine.
    Cams around the 300 degree duration as a very rough guess? with adjustable cam gears and no VVT anymore.
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Shouldn't you decide what power you want and go from there?
    Endeavour Hills
    forgot to mention trd valve springs and upgraded retainers would be the go also.
    Damien
    Brissie
    TODA Inner Shim Kit - Springs, seats, collets, retainers, buckets and shims isn't toooooo expensive. I'd imagine cheaper then TRD bits, at any rate.
    Well, for 16V at any rate.
    Endeavour Hills
    20v has "inner shims" stock though?
    Veteran corknose's Avatar
    Callum
    i know wideslider (ben) has a standard bt20v and he revs it to 9000rpm with a haltec computer.
    Damien
    Brissie
    Well, don't I look stupid. And besides the fact I was talking about 16V, so I didn't factor in the price of 4 extra buckets!
    I don't know what they do with 20V, I've only ever researched for 16V.
    Tristan
    Sorry sam I meant crank not rod. I know the bt rods are piss weak.
    Also is the weight of stock vs forged pistons of any concern?
    Is there a difference between the 16 v and 20 v 7 rib blocks?
    Endeavour Hills
    lo_rolla: I thought you where just giving an example not saying to directly get the 16V kit so it didnt seem stupid to me.
    slideways: the stock crank should be fine with 9000RPM, but some race prep would be good. Just to be safe don't get an aluminium crank puley. I know there's lots of debate over if your hurts your crank long term or not but I say it's not worth the risk for trivial if gain from having one. I would of thought in the past that piston makers would go out of their way to make something light, but from what I have seen this isn't the case. Also I don't agree with the high dome shapes on them which I think compromises the combustion chamber shape further. I like the idea of running a thinner gasket and shaving the head, old fashioned yes but I think it's superior in my crazy unexperienced theories
    Blocks are the same
  1. are bt 20v and silver top 20v cam covers the same??
    By slider4life in forum Technical - Questions
    Last Post: 1st April 2010, 06:08 PM
  2. 4age revving high
    By ae 71 ge in forum Technical - Questions
    Last Post: 10th May 2008, 03:21 AM
  3. High Revving 86 Incar rally action.
    By ae86trueno in forum Toyotas in the Media
    Last Post: 24th April 2008, 07:48 AM
