Results 1 to 8 of 8
Thread: ke70 drift suspension options???/
    Default ke70 drift suspension options???/
    hey i have a ke70 just chasing up decent suspension setup for drift if any 1 could help would be much appreciated. ive heard falcoon rears with susuki sierra shocks is decent for rear.. but fronts? please help cheeerrs
    i think i posted this in wrong forum... soorry people
    Dave
    the search button is your friend.
    start here
    dont use suzuki shocks, way to short for anything useful.
    - Blaise Pascal
    Veteran Konakid's Avatar
    Henry
    Eastern
    AE86 struts converted to coilovers with 7 or 8kg springs.
    Decent short stroke shock that can match the spring (Bilstein, KYB AGX, TRD Blue)
    Roll centre adjusters
    AE86 power steering knuckles
    Camber tops
    New front swaybar bushes
    New Castor rod bushes
    New Control arm bushes
    Strut brace
    Rear:
    5 or 6kg spring
    Shock that can match (TRD blue, Bilstein, tokico etc.
    Adjustable panhard rod
    18mm Rear swaybar
    New trailing arm bushes
    Some form of rear welded in brace.
    or cutties and sigma's........
    Senior Member .ady's Avatar
    Andy
    Footscray
    dave dave dave....serrias are awesome for sliding! if ur going budget package i.e falcon springs then serrias would be the go in my option! ive slide on these their really reliable and these do go extremely low so WIN
    cheers for the comments people.. yer its budget..hahah wats sought of falcon springs we talkin bout?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    this has been covered many times in multiple threads, I would like you to do some searching to find the answer. Until then I will lock this thread, feel free to PM me about it if needed.
  1. budget suspension setup for drift ke70
    By chickpea in forum Technical - Questions
    Last Post: 2nd April 2010, 11:52 PM
  2. KE70 suspension - for drift
    By Drain in forum Cars or Parts Wanted
    Last Post: 28th March 2010, 10:35 PM
  3. KE70 suspension - for drift
    By Drain in forum Perth & WA Events and Discussion
    Last Post: 22nd March 2010, 04:47 AM
  4. Engine Build - Valve Options - Bearing Options - Head Gasket
    By hitoriko in forum Technical - Questions
    Last Post: 19th September 2009, 05:59 PM
  5. RT142 Suspension Options
    By Steery in forum Technical - Questions
    Last Post: 9th September 2008, 08:48 PM
