Results 1 to 6 of 6
Thread: budget suspension setup for drift ke70
    Default budget suspension setup for drift ke70
    gday if any1 can help me im chasing a budget suspension setup for my ke70.. please help ..
    chickpea
    Nathan
    Lilydale
    this is whats ive done, as budget as it gets,
    ford el front springs cut for the front
    ford el rear springs cut for the rear
    vn swaybar at the back
    cut n shut arms
    lock spacer
    sierra front shocks in the back
    stock front shocks (theyre fucked haha)
    golf ball gearnob
    most of this shit can be found at the wreckers and makes ure car real solid and a little bit ghetto.
    and do some research FFS.
    Veteran slide86's Avatar
    Huw
    Hills
    WHAT THE FUCK
    your last thread was locked, pending you actually doing some research into the matter...........
    so you just start a new one and expect to get spoon fed the answers
    WEAK
    na broo i didnt no how to coninue it on i wanted budget suspensuion setup.. wats it to u bro.. it anit weakk.. just gettin used to the site cheers sprinter86
    Michael
    sa
    adelaide
    last thread shouldve been enough it was even helpful to me. just do some research then ring around wreckers and local garages etc see what they can get for you. as said previously theres lots of information if you hit search.
    you are passing another ke70
    Moderator Sam-Q's Avatar
    Endeavour Hills
    ok chickpea, I closed that last thread for a reason. Now you say your getting used to the site, let me give a run down. The search button is one of the blue buttons under the classy banner at the top. Type in things like suspension and select the tech section only to narrow it down. I am forced to say that if you open another thread without following these instructions then I will be forced to give you a warning. If you want to talk to me personally about it then send me a message but don't start another tech thread without doing some serious reading first. As long as I live in this part of the forum there will be no spoon-feeding of information as it helps no-one.
    Thread locked... again (sign)
  1. S13 suspension setup for ae86/ke70. Plus Other ke70 parts.
    By Da_Hachi in forum Car Parts For Sale
    Last Post: 28th January 2011, 10:04 AM
  2. Suspension setup for Drift....
    By baumyone in forum Technical - Questions
    Last Post: 19th December 2010, 07:03 PM
  3. ke70 suspension setup
    By biggo in forum Car Parts For Sale
    Last Post: 9th January 2008, 12:16 PM
  4. Steering Rack, Budget Suspension Setup
    By medwin46 in forum Car Parts For Sale
    Last Post: 11th December 2007, 07:28 AM
  5. drift setup front suspension for ke/ae SOLD
    By Brendo in forum Car Parts For Sale
    Last Post: 17th October 2007, 04:49 PM
