Results 1 to 10 of 13
Thread: shimming oil pump
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    Default shimming oil pump
    can anyone shine some light on how to shim a 4ag oil pump for more pressure,
    pics or explain
    ~KEEP DRIFTING FUN~
    Gunner
    remove pressure release valve, add shim behind the spring and reassemble, I use a washer with a 3mm height.
    Senior Member KENut's Avatar
    Sep 2009
    B-unit
    ACT
    canberra
    Wham bam thankyou Gunner
    PS check your pump has tight tolerances, due to their design they need to be in good nick to work well. So like no scoring on the faces etc
    Veteran Touge Boy's Avatar
    Modbury
    I bought a HKS "pressure up" kit for around $60. Comes with a new washer and a different spring.
    Apparently give oil pressures of 2-3 bar @ 500-1000 rpm, and 6-7 bar @ 2500 rpm +. So about 10-12 more PSI @ full noise.
    I currently have a different washer in there, My car currently makes around 90PSI with the boot in.
    Will be installing this on a new oil pump, so wanted the new kit to go with it.
    Mereki
    Badassville
    where did you buy this from? hks website
    ~KEEP DRIFTING FUN~
    Moderator Sam-Q's Avatar
    Endeavour Hills
    yeah whats that worth? I don't know why they would need a washer in conjuction with a new spring
    Gunner
    sounds like a bit of a gimmick to me, though I suppose, if it wasn't high enough with the spring alone, then the washer could be added.
    I'd rather the 60c washer over the $60 kit.
    Modbury
    Bought it from RHD Japan. But Ive seen it ona few websites, and ebay.
    Im already using the washer, but i figure with a new oil pump and the HKS kit, if I get over 100psi of oil pressure, then money well spent and cheap insurance. If it IS a gimmick and does what a 60c washer would do, I still have a fresh oil pump and it was only a $60 lesson learnt.
    Bryan
    Waterford
    Tramore
    Ireland
    Doesn't the HKS kit come with a restrictor for the oil feed to the head also?
    Modbury
    Nope, just the spring and the washer.
    Wondering if the restrictor is something I should look at though. Didnt think of that.
  1. Oil pump, water pump, thermostat . . .
    By AE86 Spoontah in forum Car Parts For Sale
    Last Post: 13th July 2011, 10:13 PM
  2. Oil pump.
    By Dish in forum Technical - Questions
    Last Post: 27th June 2011, 09:38 PM
  3. oil pump gasket?
    By Tim.duncan in forum Technical - Questions
    Last Post: 8th November 2009, 10:59 AM
  4. oil pump
    By nunions in forum Technical - Questions
    Last Post: 24th July 2009, 08:57 AM
