Results 1 to 2 of 2
Thread: Throttle postion sensor problem -- ?
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Default Throttle postion sensor problem -- ?
    Hi Guys, I have a 4age 16V BIG PORT n/a with a Jubride quad throttle set up. I have a problem that I am hoping you can help with.
    Engine did not have a TPS on it when i bought it . I was going to use the one off my old big port . but it will not work as it spins clock wise . The Jubride set up needs one that spins anti clock wise. Every one I have come across so far spins clock wise.
    Has any one come across this problem ? If so what TPS do I need ? A part no would be great .
    Regards Bob
    Gone
    Joel
    Picton
    hey bob - it uses 4ag 20v silvertop TPS, ill see if i have one for you
  1. 4AGE possible sensor problem?
    By jaydos in forum Technical - Questions
    Last Post: 6th March 2012, 10:56 AM
  2. AE86 reoccuring throttle problem
    By extra_anchovy in forum Technical - Questions
    Last Post: 11th August 2011, 09:38 PM
  3. throttle position sensor help
    By 17zon in forum Technical - Questions
    Last Post: 16th September 2010, 06:58 PM
  4. wtb 4AGE Map sensor and throttle sensor
    By ae86driftstyle in forum Cars or Parts Wanted
    Last Post: 22nd March 2007, 08:35 PM
  5. HELP! throttle problem
    By EMD-RA60 in forum Technical - Questions
    Last Post: 7th March 2007, 11:06 PM
