What I have here is a very good example of what the 4age is really capable of. There's not many around that push the 300kw mark and it's going cheap. The full build has been done by professionals and not on the cheap, all quality products were used.
ENGINE/DRIVLINE 340HP (17psi) 390hp (20psi)
- Gout filled block to prevent splitting under high boost
- Polished/prepped steel crank
- Argo rods
- Wisco pistons/rings 20thou
- High energy sump
- ARP main and head stud kit
- oversized ferrera valves
- Custom grind cams
- O ringed head with extensive porting etc
- Adj cam gears
- Titanium retainers
- Copper head gasket
- GT30 600hp Turbo
- Custom plenum
- Custom fuel rail
- 044 fuel pump
- 690cc injectors
- Surge tank
- Big throttle body
- Hidden away front mount
- braided lines
- Electric water pump with controller
- Power 3 core radiator
- 3 1/2inch exhaust
- Microtec lt8 with to bar map sensor
- ICE ignition
- Evo split race coils
- Microtec hand controller
- Eboost controller
- W58 Super 5 speed gear box
- Solid centre clutch
- 1 piece tail shaft
- Hilux diff full spool 4.8 diff gears
- Heavy duty axles
WHEELS AND SUSPENSION
- Lowered king springs
- New shockies
- 165 14inch front runners
- Toyo 225 14inch rear
- Also have set of Mickey Thompson street slicks 235/60 with chasers
BODY AND INTERIOR
Body is in clean, damage free condition. Paint is still in good condition, some rust on inside of hatch door. Interior needs some TLC.
Open to some swaps, either a 4x4 or travel cruiser plus cash my way.
The price is $14,000.
