Results 1 to 10 of 10
Thread: 4age 100kw injector pulse!
    Yang
    Salisbury
    Default 4age 100kw injector pulse!
    hi i just dropped in a red top motor, but for some reason none of the injectors are working (no injector pulse) can some help me with the issue?i have spark and the fuel pump is work too! thanks
    Gone
    Joel
    Picton
    did u test the pulse with and LED or NODE test light? normal incandesent test light wont work.
    you might also need to add, what car its in, what harness you used.
    Yang
    Salisbury
    dropped a motor an ae86 with 88kw harness! used injector light tester!
    Gone
    Joel
    Picton
    Their is a daignositc manual in the Tech doch page. this will help you. do the injectors have power?
    Yang
    Salisbury
    thanks mate
    Yang
    Salisbury
    can u send me a link? no injections have no power, how do i get them to power up?
    Gone
    Joel
    Picton
    power for the injectors is fed from a relay in the drivers kik panel, well it was on my 86.
    its in Tech docs. their is only one thread and the manual is called ae86 diag manual.
    Yang
    Salisbury
    ok thanks mate! iam not very good on the tech side of things! if theres anyone in South Australia which help please send me a PM!
    Daniel
    GC Hinterland
    injectors have their own relay/power feed in factory configuration. bigport are batch fire so you have your signal (usually blue) and power linked to ignition on: + (usually yellow).
    Veteran slide86's Avatar
    Huw
    Hills
    i had this problem once........
    try giving the large yellow wire on the ecu 12v power when ignition is on and see if the car comes to life.
  1. Weak injector pulse
    By Matt in forum Technical - Questions
    Last Post: 18th December 2011, 11:54 PM
  2. No injector pulse on 4agze
    By Sprintn in forum Technical - Questions
    Last Post: 19th September 2011, 06:09 PM
  3. no injector pulse 4age
    By cozmic in forum Technical - Questions
    Last Post: 7th February 2010, 10:56 AM
  4. noid test light for testing for injector pulse
    By johnO2 in forum Technical - Questions
    Last Post: 7th August 2008, 10:07 PM
  5. injector pulse
    Last Post: 30th July 2008, 12:28 AM
