you would only need to lip the guards, and have a bit of stretch
this is a shit picture but you should get the idea
14x8 -15 is flush for all stock 86 guards just need to lip the inside
Rust is a way of life
on the front of my ke70 im running 14x7.5 -2, they basically sit 1 or 2mm outside the guards this will change when i put xt130 lca's in
15 x 7 -1
8jj-12 become -26 when flipped?
is that flush?
what lca and camber are you running?
yeh pretty much dead flush. no cambertops just xt130 lca, 40mm rca
sweet thanks mate
ke70 lcas and then camber them in and should be a perfect fit
