Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: **** Bretts thread- Purple JDM Garage Ae86 -parting out, for sale ****
    Senior Member kaibeecee's Avatar
    Pete
    Default PurpleJDM Garage Ae86 -parting out **WHEELS NOW and pictures ADDED
    For sale: Pretty much every part off my car
    Contact: Brett Mattingley- 0433 191 205 please call rather than PMing as im not on the net much
    PLEASE READ BEFORE POSTING, CALLING OR PM'ing
    - DONT ask to swap parts
    - DONT ask for parts to be held for you, its first in best dressed
    - please DONT comment on the fact the car is being parted out, it sucks enough already
    - DONT ask me to post stuff that I have labeled NOT POSTABLE
    - DONT ask me to include postage in the already mentioned price
    Parts for sale
    • 4 x longchamps as in the photo above, wheels are 15" x 9.5" rear and 15" x 9.2" front, front wheels are machined behind to fit larger calipers, good front tyres, rear tyres are down to the tread wear indicators.
    Wheels have a front spacing of 150mm (from the hub to the outer lip of the rim)
    $2200 for 4
    • Diff- 4.3 E series, 4” extended lower mounts, enlarged breather with Speed flow fittings, new bearings, s13 disks with ENDLESS brake pads, braided lines to the diff and to the callipers, T3 rubber (reusable) diff gasket, diff centre built by TOP COG is a locked centre, diff housing painted in gray urethane 2pack. I have run this rear end for the past year without a problem, the diff has quality oil in it and is ready to go
    $1100 (no post but will frieght if you organize it)
    • HKS 256, 264 cams, (SR20) Tomei rocker stoppers, Tomei cam gears
    $700 (WILL NOT RELEASE TILL MOTOR PACKAGE SELLS)
    • SARD 850cc SR20 injectors
    $400 (WILL NOT RELEASE TILL MOTOR PACKAGE SELLS)
    • Z32 afm
    $150 (WILL NOT RELEASE TILL MOTOR PACKAGE SELLS)
    • APEXI powerFC, hand controller and Boost control unit
    $800 (WILL NOT RELEASE TILL MOTOR SELLS)[/B][/SIZE]
    [B][SIZE="4"]• Front Greddy strut brace
    $200
    • Nizmo 65deg thermostat
    $50.oo
    • Full Engine package WITH MOUNTS For AE86 or KE70- (PART 1) s14 ‘lumpy top’ SR20det,
    - Engine + puck Clutch and custom flywheel
    - R33 na Gearbox + Short shifter
    - 3" tail shaft
    - Large radiator + thermos
    - Engine and gearbox mounts to suit AE86 or KE70
    - painted rocker cover with earls fittings
    - NA throttle body (larger)
    - all unused holes welded up in inlet manifold
    - deleted AAC valve (idle control valve, give much quicker throttle response)
    - oil lines tapped straight into block
    - Trust oil cooler, braided lines and oil filter relocation block
    - Modified and simplified engine loom
    - 3” stainless exhaust with split dump and screamer pipe
    - Greddy water pump pulley
    - high volume sump
    - JAP tunned length exhaust manifold
    - HKS 2510 ball bearing turbo (bought new, done little work) with HKS adjustable actuator
    - Speedflow braided water and oil feed lines
    - front mount 600x300x75mm intercooler and alloy pipping including silicon joiners and clamps and brackets
    Motor made 171RWKW at 14psi (only runs 10psi atm, 165RWKW)
    $4500 or $3700 without turbo (will fit package) (will freight)
    - Can also include (PART 2) Apexi Power FC, hand controller, boost control unit, Z32 afm, SARD 850cc injectors $1000 extra
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    pm'd on nardi
    the dyno pull to 300rwkw
    Pete
    Pm repleyed
    E-Famous (Remeber your roots)
    How much for bare shell?
    Seam welded?
    Welded in half cage?
    ADM or JDM?
    ACT
    Compton
    hey mate,have you pics of the nardi?thanks
    Veteran slydar's Avatar
    Dimitri
    the shell is adm, seam/stich welded and the cage is welded in. if you are actually interested marvis, call brett. if you want to drive it on the road etc he can possibly modify it to suit your needs.
    having said all that, the operative sentence in the above phrase is. call brett this is a legitimate sale. not a net monkey chat fest.
    78's
    Pete
    All PM's replyed too,
    Will try and post up pics of parts tonight or thursday morning,
    if you would like a pic of a particular part then let me know,
    (parts can also be looked at if your in Brisbane and want to come take a look)
    Mar 2010
    Sean
    how much for the front coilovers
    Pete
    • Front suspension –everything you need
    - Rose jointed and braced s13 control arms
    - Rose jointed s13 caster arms (comes with caster brackets)
    - Rose jointed Swaybar link pins
    - HSD base adjustable, height adjustable and damper adjustable Coilovers, 8kg springs
    - HSD camber tops
    - S13 sr20 calipers
    - Endless pads
    - S13 sr20 slotted and cross drilled disks
    - Braided brake lines
    - Hubs modified for extreme lock
    - Rose jointed Tune Agent tie-rod ends
    - Custom rack ends
    $1800 or $1600 traded for factory stuff (WILL FIT / SWAP PARTS IF NEEDED) (will not freight)
    Member schubey's Avatar
    Nov 2009
    Luke
    ya mum
    hectic shit. shotgun the seat. Will call you 2moro.
  1. 1987 Jdm purple notchy ae86 wrecking
    Last Post: 7th August 2011, 04:09 PM
  2. AE86 JDM garage super bust out sale
    By hachirusto in forum Car Parts For Sale
    Last Post: 8th April 2010, 12:07 PM
  3. AE86 garage sale heaps of jdm yo
    Last Post: 12th September 2009, 08:17 PM
  4. Bretts N2 kitted ae86
    By uganga in forum AE86 Owners Forums
    Last Post: 2nd October 2008, 11:33 AM
  5. Bretts Purple People Eater
    By roger roger in forum Toyotas in the Media
    Last Post: 28th August 2008, 08:36 PM
