I started my 4AGE the other day and all my vacuum ports are blocked off. MAP sensor and fuel reg are connected though.
when i start the car, the dizzy is set to retarted but once i get the right timing the revs shoot straight up and stay there and doesnt change even when i play with the dizzy again.
its a 4age bigport with tvis removed
would anyone have a idea what could be causing this?
in the build KE70... whats next?
my idle is also weird ... it sounds like you have the same issues as me ... ive worked it out to be the wax idle speed controller ...
check out my thread and tell me if its similar
