After doing some reading and trawling regarding adjusting the rear camber on my cressida, would like to hear other opinions and ideas on the topic.
The same concepts apply to all 80s toyotas with IRS Including MX73 and earlier, RA, MA, SA etc.
From what i can gather making the mounting tab on the rear subframe (where the rear control arm mounts) elongated to adjust. Like so:
Im not sure if its just me, or having adjustment like that seems it would be easily moved if i were to hit a ripple strip or similar? or would it be fine.
I read this changes the suspension travel arc. im not 100% sure what is meant by this, but i would assume its the difference in angle between that and the toe adjusting tab? if anyone could elaborate on this? or if its not even worth worrying about.
So yea, i plan on going ahead with the adjustment tabs, unless someone has any better ideas.
Also interested to know how much camber adjustment you could get out of them, i currently have alot (see pic below) and want around 0 to -1 degrees.
Cheers guys
