Results 11 to 20 of 21
Thread: W series gearbox conversion requirements?
  1. #11
    Veteran slide86's Avatar
    Huw
    Hills
    yes thats correct davey.
    extreme clutch down at regency park can do that work for you. no need to change pressure plate or flywheel, just the actual disc splines
  2. #12
    Ok
    Seamus
    Milton
    There really isn't much more info about it, as AZ-customs doesnt go on the interwebs, so not many people (other than myself and a few others) bought his stuff. If you want to get in contact with the guy, i would try the fella who started this thread:
    He seems to get alot of stuff done by AZ, so should be able to point you in the right direction.
  3. #13
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    i told u the other night on msn!!! only a swap tho
    AE86 THE BEST
  4. #14
    Senior Member AE86 Spoontah's Avatar
    Brendon
    Ellenbrook
    Would it not be wise for people to post what gearbox, bellhousing, crossmember, tailshaft, flywheel, clutch, fork and throwout bearing and slave they are using on a proven setup and then have the post stickied?
    Here is mine that i have finally got sorted.
    Gearbox: W57
    Bellhousing: Bill Sherwood adapter
    Crossmember: Custom made
    Tailshaft: Custom one piece
    Flywheel: Stock 4AGE
    Clutch: Exedy 4 Puck with 28spline (custom made)
    Fork: Supra
    Throwout bearing: Supra
    Slave: T-18
  5. #15
    Davey & Riki-lee
    South Australia
    Seaford SA
    I agree a sticky would be better that way people like me dont have to post it up all the time!
    Good layout thanks for posting that, thats what i was after so all W series boxs are 28 splines?
    just want to ask to be sure when getting the splines changed over. thanks again
    Our introduction - Click here
  6. #16
    Brendon
    Ellenbrook
    Yeah i'm pretty sure they all are. I told the clutch place i wanted a 4AGE 4 puck clutch with a supra spline in it and he said no worries. cost me about $250 for clutch and 2.2 tonne pressure plate.
  7. #17
    Mar 2010
    mark
    qld
    brisbane
    Diggin up an old one lol
    Is there any advantage in running the GZE flywheel? if so why?
  8. #18
    Veteran Skylar's Avatar
    Ken
    uhhh, you can run gze clutch which has the right spline in the clutch plate. and it's heavy as shit too. clutch kicks work better but more chance of driveline fails.
  9. #19
    kyle
    Newport
    What about the speedo does the standard t50 speedo cable go into the w5x speedo gear or do you use the t50 cable and gear?
  10. #20
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Cable attatchment is the same on both. T50 cable will work fine on W58.
    Andrew
  1. wtb T SERIES TAIL SHAFT or Complete W Series Gearbox Conversion
    By Vaughn in forum Cars or Parts Wanted
    Last Post: 11th December 2012, 09:21 PM
  2. WTB: W series gearbox conversion for 4age
    By 4agte70 in forum Cars or Parts Wanted
    Last Post: 6th July 2010, 09:06 PM
  3. Camshaft requirements
    By mulkers in forum Technical - Questions
    Last Post: 6th June 2006, 08:06 PM
  4. Torque requirements
    By v-tec in forum General Topics (No Technical Questions)
    Last Post: 5th October 2005, 07:10 PM
