Results 1 to 10 of 10
Thread: Remove AW11 Steering wheel
    Apr 2010
    Default Remove AW11 Steering wheel
    Want to fit a aftermarket boss kit and steering wheel, however the
    original AW11 steering wheel very hard to pull out after 17"mm centre nuts removed.
    Is there any tricky way?
    Thank you very much!
    Veteran timbo's Avatar
    Tim?
    Wild West
    wd40 and lots of twisting and turning! be persistent, it will come off after time. i has the same problem with my old wheel.
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    What Tim said^. I think you can buy a special steering wheel removing tool from your local Supercheap Auto. I've never used one before so I don't know how good they are.
    Remember not to completely remove the nut in the centre! leave it sitting on the shaft by a few threads...that way it won't fly off and smash you in your face when you're yanking on it.
    Apr 2010
    Cool, I will try.
    Jay
    yea you can buy a steering wheel puller from super cheap , Ive got one and it works well to crack then nut and then you just unscrew it once its cracked
    Rust is a way of life
    Glenn ke_70's Avatar
    Clay
    Barossa!
    cant say ive ever had a stuck steering wheel. even in my ke70 that would of never come off before
    i pushed and pulled from the top and bottom for some reason it never budges from the sides. and theres no risk of hitting your self either this way
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    wd40 the shit out of it
    leave nut on the end so you dont smack yourself in the face
    sit in the seat and use arms and knees to pull on it.
    comes off eventually.
    E-Famous (Remeber your roots)
    Yep. Also you can do that and have someone hit the nut.
    Apr 2010
    Steering wheel come off finally, repeat using WD-40 for serval days, and finally pulled out.
    Thx for everyone!
    Tim?
    Wild West
    patience is a virtue!
  1. Replies: 3
    Last Post: 29th November 2011, 08:20 PM
  2. Replies: 5
    Last Post: 18th April 2011, 03:56 PM
  3. how to remove steering wheel
    By khai2298 in forum Technical - Questions
    Last Post: 2nd October 2009, 01:19 PM
  4. How to remove power steering arms from car?
    By patience in forum Technical - Questions
    Last Post: 11th July 2008, 11:59 AM
  5. how the hell do ya remove a sprinter's steering wheel?
    By sprinters_r_mad in forum Technical - Questions
    Last Post: 25th November 2006, 01:38 PM
