Hey all, ive got a few things here so lets get on with it...
At this stage i dont want to post any items, local pickup only...
AE86 ~~ o_0
Zenki levin front bumper with MX73 lip, inc mounts, good condition could do with some paint
$200
Trueno FRP Bonnet - Needs some work hasnt been run before, has proper ribbing, catch and hinge threads
$250
Toyota genuine rwd 4age waterpump inc backhousing used
$70
Slat grille x 2 - Both have 2 clips broken, good condition otherwise
$50ea
Euro letterbox grille - very good condition all clips good, some peeling on the front
$180 SOLD
Factory electric sunroof - Including mint sunken rooflining, maplights, loom, everything you need to convert.
Sunroof panel has some rust
$240
4a crossmember
$75
OE front swaybar and castor rods
$40
Control arms inc bushes and balljoints
$30ea
Levin RH headlight
$80
JDM T50 with bellhousing, shifter, clutch slave, crossmember with broken mount
$500
T50 x 2 with adm bellhousing
$hmmm
T50 suit parts/rebuild
$50
Smallport 4age head inc cams, valves, springs. no bearing caps afaik probably can find some somewhere.
$90
Dash uncracked JDM brown, has two holes to the left of the wiper switch from an old guage
$150
Hatch Struts - good condition THESE ARE GASLIFT STRUTS FOR REAR HATCH not suspension
$20ea
Bigport cams x 2
$50pr
Cage 4 point - not sure of brand, black bolt in, including plates for underneath
$390
ADM Fuel tank - comes with sender
$100
Rear bumper x 2 - One in ok condition, one damaged on lhs
$50, $20
3puk clutch + pressure plate 200mm
$90
200mm Flywheel
$50 or swap for 212mm
Buzz spec 4 way front shocks suit rebuild
$40
Metal crash bar behind dash
$30
Whiteline 18mm Rear swaybar inc bushes
$100 SOLD
Manual steering rack - only one rackend currently, can supply 2 new rackends cheap
$130
Clutch pedal box and brake pedal box
$30ea
Jap bigport 97kw ECU
$100 SOLD
KE70 ~~
Bigport 3K head - further ported, inc valves etc
$90 SOLD
3K rocker cover
$10
4K airfilter housing x 2
$10ea
Tercel 17mm rear swaybar inc bushes + d brackets
$80 withdrawn
Steering rack
$35
4K carby suit rebuild
$10
AE82 ~~
Brand new! Front struts single cam KYB
$140pr
Twincam Rear spoiler
$50
FOHA front lip in rubber, has a small repair on it
$120
Bonnet, White
$50
4AC headgasket x 2
$15 ea
MISC ~~
Mazda BP 1.8 '99 100k
Has crankwalk, good head, inc coilpacks sensors clutch etc
$200
SR20 ACL race metal headgasket - Brand new
$180
Honda dc2 Integra floormatts, genuine 5 piece good condition
$offers
Pics available upon request, more items will be added, best to call or sms me but ill try my best to get on here to check the thread
040 1337 020
Located in North eastern burbs
