Hi please find attach the list of parts included in the deal. The engine has balanced cranshaft with pistons & conrods.
Ported and polished cylinder head to TRD standards for such camshafts. Compression ratio is above 13to1. Only 100 octane fuel used.
Comes with complete exhaust system (manifold to final muffler),101 4age 4 throttles injection,mocal oil cooler, koyo radiator, custom engine wiring
Yani says:
& HKS fcon v pro ecu, gearbox and propeler shaft.
I will give u as well the fuel line (teflon), fuel pump and external fuel tank.
The engine output is around 200bhp,redline is 8800rpm. The engine was tuned by Doctor Susumo Koyama from JUN AUTO MECHANIC Japan.
Complete set up for 6000 euro.
Plus shipping. will have to pm me if interested to find shipping cost for you
But max shipping would be another 500 all over the world
Stock crankshaft ( balanced with pistons & conrods )
Tec Arts conrods
Tec Arts pistons
Ported and polished cylender head to trd specifications
HKS camshafts
HKS Head gasket
HKS Titanium valve spring kit
Jun cam gear
Sard injetors
4 throttle from 20v engine
Jubiride throttle air plate
Jubiride adaptor plate
Jubiride curl funnels 30mm
Techno pro Spirit water pump
Toda oil pump
Jun Flywheel
Act clutch kit
HKS exhaust Manifold
Jubiride Exhaust System
Custom engine wiring( fuse holder box & relay included )
Fcon v pro ecu (Tuned by Susumo Koyama from JUN )
Toyota direct coil ignition
External fuel pump (with teflon fuel line and racing 20L fuel cell)
Koyo aluminium 3 layers radiator
Heres a video of the engine on my car
