Results 1 to 3 of 3
Thread: AE86 springs into xE7x
    Jun 2009
    Ollie
    Default AE86 springs into xE7x
    Hey, ive got ae86 struts, and springs to go into my ae71. Im also planning to use t3 camber plates. What i want to know is, what will i need to go btw the top of the spring and the camber plate (i dont know what this is called... top hat??). Will the original one be big enough for the ae86 spring, or will i need 86 top hats to be able to run the 86 spring??
    Veteran stx-16's Avatar
    Tweed Heads
    from what i can remember the ae71 and ae86 springs are the same size if there not there not far off
    because i had ae86 springs in my ke70 struts before i went coil overs.
    so yer the top hat from your ae71 struts should be fine to use with the t3 camber top/plate
    you play halo?
    add me GT: samnbhnc
    Jun 2009
    Ollie
    Sweet as, thanks a lot man. Didnt want to get to the point where everything was out and find that i needed to get new tops. I might take a spring out to a wrecker and test fit it anyway, but if i dont get a chance then i will just roll with it and hope for the best!
  1. xe7x Diff into ae86
    By odessy in forum Technical - Questions
    Last Post: 25th October 2011, 02:04 PM
  2. (SA) xE7x / AE86 Boss kit
    By Seventy in forum Car Parts For Sale
    Last Post: 18th August 2011, 01:48 AM
  3. xe7x front king springs & struts with chop au springs
    By Ke70-noob in forum Car Parts For Sale
    Last Post: 12th May 2011, 04:46 PM
  4. Xe7X rear leaf springs
    By starni_boy in forum Cars or Parts Wanted
    Last Post: 19th April 2011, 07:35 PM
  5. xe7x-ae86 bonnet latches
    By TRD_86 in forum Technical - Questions
    Last Post: 27th August 2008, 11:33 PM
