a 16v uses 5 short and 5 long bolts,
a 20V uses 10 of the longer bolts
Its all in the title.
I am bolting a 20v bottom end to a bigport 16 head.
And, after a bit of a read, the studs ARE different, but how?
i.e. which ones should i bloody order! haha
cheers guys
Mint. is it the head or the block that determines the bolt lenths?
i.e. do half thread further into the block on a 16v, or is it because of the head design that 5 need to stick out further?
cheers as always sam!
it's the head that does, apparently it's is possible to get the 20V kit now, however if you can't I can give the part numbers for each individual component needed for the 20V head.
Well, 16v kit it is then!
wealth of info sam, ta
whoa, nah you need the 20V head with the 20V head, it's the head that determines it, that part of all the A blocks are identical. Find out if they sell the 20V kit now and post back here. I will give you those part numbers should you need it
Re-read my first post sam, i have a 16v BIGPORT head.
on a 20v SILVERTOP bottom end
lolz!
yep my bad, as you where
yeah confused me too. mostly because you bolt the head to the bottom end and not the other way around
If you want ARP Bolts, Road and Track has 20V kits as well as the common 16V kit. Paid $240 for my 20V kit delivered, 16V is a similar price.
