Front pair of ajps with bilstein insert coilovers. Perfect street, hills, tarmac set up
Brand new.
Run an inverted monotube B6 insert (60mm removed from strut)
King spring hi tensile coilover springs (200mm) in 5.8kg and 65mm helper springs
Can come with RCA, Camber tops, ps arms and rear 3.5g springs as a package etc.
I need change over struts. If you want these struts (no hubs) add $200.
Coilover kit is $300, shocks are $660 with the fine thread gland nuts, springs are $250, helpers with separators are $240, labour and the machining on the spring perch and the bearing spacer $220
= $1670 with changeover.
Ill do them for $1550.
I run these coilovers in my car with a 7.0kg spring.
Enjoy.
Ps. Ive got 3 sets of cusco caster rods in stock. Pm me
