Results 1 to 7 of 7
Thread: how to change rear main seals
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Default how to change rear main seals
    hey guy. i want to change my rear main seal. can anyone give me some instructions and what not as it seems abit difficult for me
    Pick up Sydney
    Pics can be sent by phone
    Emails ignored
    Texts ignored
    Private numbers ignored
    Wankers abused
    Senior Member KENut's Avatar
    Sep 2009
    B-unit
    ACT
    canberra
    Ok I'm not very good at explaining stuff but here goes;
    First of all take gearbox out and all that jazz (or alternatively pull the engine out, just as easy really)
    Now the clutch and flywheel need to come off. Mark where the clutch is on the flywheel, and where the flywheel is on the crank.
    Unbolt the rear main seal (6bolts?). This can be a prick if the studs are still in it, which will mean you have to drop the rear of the sump. Replace these studs with bolts while you're at it.
    With hammer and some sort of punch, knock the old main seal out of its housing.
    Install new one into the housing by tapping it in squarely with a SOFT hammer. Run a little bit of high temp grease around the inside lip.
    Install everything in reverse of removal. Hopefully i havent missed anything
    Good luck
    Phuoc
    Liverpool
    im kinda lost there.. the flywheel n all that is out.. i can see the big seal n small pilot one. are you able to post a pic as it will be easier to understand. thanks
    Pick up Sydney
    Emails ignored
    Texts ignored
    Wankers abused
    Sep 2009
    B-unit
    ACT
    canberra
    Not a great pic, but the dark blue circular seal around the crank is the main seal. May need to take off backing plate if you havent already
    Undo the 6 bolts and undo the nuts holding the sump on until the sump bolt holes at the back clear the studs,
    Then pry off the aluminium seal housing, flip it around, wack the old seal out, put new one in
    just get yourself a manual for the engine, lots of pictures.
    i have the "4age big blue book" which is the best one, around 92mb. its huuuugggee. got anythign you ever wanted to know about 4age. actually here is a link to it:
    - Blaise Pascal
    Member Aezion's Avatar
    Seb
    I replaced mine about 2 months ago, i just used a screw driver & hammer to pop out the old one doesnt matter if you break it because your replacing it anyways.
    I didnt seal it up, but i just lubed up the main seal (rubber ring thingy) with some oil and gently popped it into place with a rubber hammer.
    Make sure you swing off the bolts when your putting your flywheel back on, you dont want that motherf*^%ker coming off.
    Veteran shift_rook's Avatar
    SE Burbs
    when you're putting flywheel back on you should use lcok tight and a torque wrench as you can also overtighten bolts which stretches them and makes them weak
  1. AE101 4AGZE rear main seal
    By Intense in forum Technical - Questions
    Last Post: 5th January 2010, 04:25 PM
  2. rear main seal
    By sic86 in forum Cars or Parts Wanted
    Last Post: 13th October 2009, 01:17 AM
  3. 4age rear main oil seal
    By driftster in forum Technical - Questions
    Last Post: 27th June 2007, 02:34 PM
  4. ae101 rear main seal
    By Blown86 in forum Technical - Questions
    Last Post: 29th August 2005, 08:53 PM
