Results 11 to 20 of 30
Thread: KE70 VS AE71 need some info
  1. #11
    Veteran Konakid's Avatar
    Henry
    Eastern
    What he said.
  2. #12
    Veteran skizzamods's Avatar
    Oscar
    Adelaide Hills
    yeah I went from a ke70 to ae71, and in the future I wouldn't think about a ke70 unless it was mint, or you have parts readily available for whatever you are going to put in it.
    If you don't like slanty, just convert it.
  3. #13
    Gone
    Joel
    Picton
    or unless its dirt cheap.. like $200 - the 71's ive seen for sale have been up around 1500 - 2k
  4. #14
    Henry
    Eastern
    AE71's are worth 2K
  5. #15
    Senior Member (OO)SKYLINE(OO)'s Avatar
    Jun 2009
    Jamie
    East
    AUS
    I have had both KE70 and AE71
    I have the AE71 at the moment.
    I like the AE71 as it has the 5 speed manual and the 1.6lt (4AC) VS the 4K which had the 4 speed manual, 1.3lt.
    The good thing is that the parts are interchangeable, for example the doors front guards and bonnet.
    I actual prefer the Flat Front on the KE70 vs the Slant Front AE71.
    One day I would like to convert my Slant Front to a Flat Front as I think it looks tougher
    AE71 might be worth more cuz it is a higher level trim of car... Maybe
  6. #16
    Dave
    on this forum perhaps.
    to the rest of the world both cars are worth nothing.
    keep searching the trading post for a more realistic price.
    having said that any ke70/ae71 (or any old car in general) that is able to pass a RWC first go i think is worth $600-800. if it cannot the price should be significantly lower, as passing RWC legitimately is not an easy task on a 30yr old car unless it has had some work done recently and/or kept well maintained.
    - Blaise Pascal
  7. #17
    Gone
    Joel
    Picton
    no way i would pay 2k for a 71 - most ppl on this forum would gut the thing and replace it with 86 gear and a 4a
    so if u get a 70 for $200, $250 for pedal box, $200 x members, $80 clutch master, $100 tail shaft - basically you have a gutted 71.
    you can do a 70 cheaper then a 71 np.
    and 70's look better
  8. #18
    Dave
    man where you geting your clutch masters!
    $47 band new from repco, around $30 for the slave.
    - Blaise Pascal
  9. #19
    Veteran shift_rook's Avatar
    SE Burbs
    let me know when you find a ke on here for $200, you only find cheap e7s on the side of the road etc etc, so whether it's an ae or ke if you're lucky enough to spot one they should both hopefully be pretty cheap
  10. #20
    Gone
    Joel
    Picton
    yeah it was just a guess dave, i did find a 70 on here for $200, check my build thread.
  1. Need tips/info on selling me ke70
    By FAST EDDIE in forum General Topics (No Technical Questions)
    Last Post: 17th November 2011, 09:03 PM
  2. Need some KE70 wiring info
    By Simon-KE70 in forum Technical - Questions
    Last Post: 10th February 2009, 08:04 PM
  3. SR20 into KE70 wiring info
    By Simon-AE86 in forum Technical - Questions
    Last Post: 20th June 2008, 08:14 AM
  4. AE71 info
    By li21 in forum Technical - Questions
    Last Post: 20th August 2006, 11:43 AM
  5. AE71 info
    By brad in forum General Topics (No Technical Questions)
    Last Post: 2nd June 2006, 05:10 PM
