Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 41 to 50 of 68
Thread: Rear coilover options?
  1. #41
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi
    I am running TRD unit very similar to the ones that Dom86 has shown up first
    They are a TRD Red and very nice , from N2 racing and have the nicely shapped aluminium billet to fit up into the sandard cup in the rear chassis for the better distribution of the weight and forces.
    They don't come cheap like this though even sec hand
    I also have 2 sets of these in Japan ready for the next container.
    cheers
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
  2. #42
    Moderator Sam-Q's Avatar
    Endeavour Hills
    you know all this talk about it being a weak area and all makes me think. I have put a grinder through this area and the metal is fairly thick, sure it isn't almost completely under tension but it does seem thicker than a strut tower to me
  3. #43
    Glenn ke_70's Avatar
    Clay
    Barossa!
    i think it'd be strong enough unless it rally or similar harsh roads
  4. #44
    Endeavour Hills
    I cant see it failing under any conditions
  5. #45
    Clay
    Barossa!
    yeah your probley right
  6. #46
    Endeavour Hills
    oh boy... ok if anyone converts to rear coil-overs make a mental note not to do that
  7. #47
    Veteran slydar's Avatar
    Dimitri
    the shock tower is 3 layers thick. the top will never fail i dont think. especially with a few extra spots around the seem. the diff mount maybe, but not if its gusseted.
    re springs. im pretty sure any decent motorsport suplier can provide you 1.9" i.e springs now. that is what the gaz kit uses. 2.25 is what the kits ive been using use on the front..
    78's
  8. #48
    yer king springs can do up custom made springs for a pretty reasonable price.
    i got some made up a few years ago. you just specifiy rate, free height, and ID.
    - Blaise Pascal
  9. #49
    Senior Member GOODY's Avatar
    Logan
    I've recieved an email back from Gaz shocks in the UK and they have sent me this picture below. They are not the actual coilover but are pretty much what they will look like apart from some different top fittings and zinc coating/colours.
    What do you guys think? Anything special I should be asking for? What sort of spring rate should I be wanting if the car is going to be used mainly for drift and daily driving. I would like it to be fairly stiff..
Name:	Gaz coilovers..jpg
  10. #50
    Veteran Konakid's Avatar
    Henry
    Eastern
    5kg should be perfect with a swaybar.
    RT142 Estate.
    AJPS.
  1. Coilover Sale - AE86 Front + Rear Springs & Shocks - S13 Rear
    By Skid_KE70 in forum Car Parts For Sale
    Last Post: 10th October 2012, 03:07 PM
  2. rear brake options on KE70
    By 20v ae71 in forum Technical - Questions
    Last Post: 27th May 2011, 06:36 PM
  3. Rear Brake options
    By TUF 086 in forum Technical - Questions
    Last Post: 15th August 2007, 05:07 PM
  4. rear end options
    By starni_boy in forum Technical - Questions
    Last Post: 24th January 2007, 08:11 PM
  5. Live rear axle options
    By Skin in forum Technical - Questions
    Last Post: 3rd February 2006, 12:52 AM
