Cheapest option would be just a simple swap to JDM callipers and rotors, some decent pads and fluid and you will be very surprised with the result! It will be plenty for the 20v![]()
Hi all, thought I'd ask a bit of advise bout my project...
Got a KE70 im puttin a 20V in, doing brakes and suspension atm.
Was planning to do bigger front brake upgrade, but not sure what would be the best/easiest/cheapest option for me.... Whats compatible with what???
Anyone help me out as to what would be a good combo and everything that would be neccesary to do the upgrade...
Thanx for any help...
if you can afford eitheer the wilwood big brake upgrade(though then you have to run a 15" wheel) or rx7( you can stick to 14's) or jdm if you want to do it a bit cheaper, though remember for all of these upgrades you'll still have to buy ae86 struts
