no need for google, there is related topics on here...
any links to this nobybooth one?
tried to google but found nothing.
BENT MECHANIX - Garage 20:
Unsure how much room you have with the MCs, but another off the shelf option is this:
Costs about $200 delivered, and can be easily cut up to suit almost anything.
tupper wear. im serious. at least to base the mould/base off.
78's
ah, intuitive D I like it...
i like the look of that.
do you think it looks a bit small? will it restrict the power at all you think?
might look into it.
i had a go at making a template of a plastic water container....
3 hours later i decided i diddnt have all the idea thaught out.
in my head it was going to be awsome.
hire a 3d printer....![]()
06/07/2011
my air box is 12 litres in capacity
these pics are getting old now:
that thing made of steel?
i bet its pretty heavy!
cool idea though.
the easiest way would be to make a mould out of something cheap and easy, like cardboard and wood. then go nuts with fibreglass matting and resin.
glass is really easy to work with, and you cant really stuff it up. unless you dont put enough hardener in.
you would need to plan the mould though, as you would need to do it in 2 parts, or maybe even 3. as you need to be able to get the mould out of the fibreglass when its finished.
you could make it pretty sweet looking, and you could make it mould around anything, like the brake booster/clutch thing etc. just cut out what you need to clear, and then patch it up again.
- Blaise Pascal
