Results 1 to 7 of 7
Thread: Cooling setup for 4agte V-mount
    Senior Member n00bvak's Avatar
    Novak
    SOR
    Default Cooling setup for 4agte V-mount
    Car - ke70
    motor - 4agte
    use - Cooling arrangement for header tank & turbo
    problem - dont know how to run cooling to turbo/header tank
    occurs/started when - when I put it together
    Details:
    Hey Guys,
    I've cut my car up, installed V-mount for the rice and epic drifto, booked the car into get the ECU wired/tuned up next week and I need to get the cooling system sorted out before it goes in.
    From all the googling I have done, it looks like most ppl run water to the turbo by tee 'ing off the heater lines. Not running a heater box so I'm hoping it is as easy as the diagram below.
    What I don't know if the line from the turbo to the header tank will flow enough to cool the turbo and not too much to create too much pressure and bye bye turbo. Will it fill the header tank too fast and just spit it into the overflow bottle? Or simply if what I am thinking is just completely wrong and there is a way better way to do it?
    Has anyone run a header tank on there 4agte and if so help please? Any advice would be great and photo's would be awesome too!
    --- All your base are belong to Phil Bradshaw!!! ---
    <<< blog >>> build thread<<<
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Diagram looks fine...
    I'd try to mount the header tank higher than ther rest of the cooling system and then remove the cap from the radiator as its no longer needed because of the bleed pipe that runs up to the header..
    Also make sure that the bleed pipe is mounted on the highest point of the radiator...
    Novak
    SOR
    Yep thats cool, I should be mounting it on the strut tower as high up as it will go.
    I'm not one that knows about fluid dynamics, but I guess that because there is only one pump in the system, and as long as I dont go from a small pipe to a big pipe (due to venturi affect and differential pressures?) the pressure should stay the same around the whole system. Therefore the header tank should not overflow???
    Well that sound correct in my head, but I dont really know much?
    Jason
    Nundah
    The header tank is basically just a remote resivour. It needs to be fitted with a normal preasurized radiator cap and shouldn't overflow...
    I don't think the pump would have anything to do with the preasure in the system.. it only moves the water.. The heat is what increases the preasure..
    And that inturn will create some water movement through some of the external piping as the heat rises and the cold obviously falls..
    Novak
    SOR
    I get it, just clicked; thanks Redwork.
    It works just like the radiator, it wont overflow untill the pressure is greater than the rating of the radiator cap. I was over complicating it in my head, of course the header tank is pressurised
    Anyone else think that there is a better way to do this, or have I got it pretty much right?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    yes the header tank should have pressure and will just work like, the top and bottom tanks in a radiator, and when the pressure gets too high the in header tank the radiator cap will release it just like it would if you had it on the rad
    Novak
    SOR
    also, Im running an ae92 remote thermostat and was thinking of running the the header tank return to the top inlet of the thermostat housing, as in the image?
    That seems to be the return for the heater anyway, just wanna be 100%
  1. WTB cooling setup to suit Jdm bigport
    By Jman_KE70 in forum Cars or Parts Wanted
    Last Post: 21st March 2012, 10:53 AM
  2. complete RWD cooling system setup & GZE Crank angle sensor
    By slide86 in forum Car Parts For Sale
    Last Post: 7th January 2011, 10:15 AM
  3. Replies: 1
    Last Post: 3rd November 2010, 09:19 AM
  4. WTD: Full RWD cooling system setup
    By joshuad in forum Cars or Parts Wanted
    Last Post: 28th July 2010, 07:46 PM
