Results 1 to 10 of 15
Thread: why do i have no power? - smallport ae82 in ke70
    Senior Member dunga70's Avatar
    Jay
    Shire
    Default why do i have no power? - smallport ae82 in ke70
    was running fine then bang! someone stole my power?
    its slower than a stock 4k now.. i think the tps was playing up could that be it?
    its still running on all 4 cylinders but wont go anywhere?
    any ideas fellas?
    olympic gold keto
    Veteran timbo's Avatar
    Tim?
    Wild West
    more info please.
    Jay
    Shire
    It runs.. U put ur foor down and it doesn't go anywhere.. Was working fine The just died in the ass. The distributor is leaking oil but doubt it has to do with that.. Thinking it could be more the throtle position sensor which i was told is worn out which makes my idle fluctuate ?? What other info u after?
    olympic gold keto
    Glenn ke_70's Avatar
    Clay
    Barossa!
    does it still rev?
    Jay
    Shire
    It Revs in neutral.. Not quite as quick as normal. And has abit if a splutter on the way up and a cough in the exhaust in the way down.. When driving it revs but takes forever
    olympic gold keto
    Tim?
    Wild West
    ok so under load there is no power.
    - quickest way to determine if its your TPS is to loosen it with the engine on and move it around to see if the revs change, if they don't then you have a TPS problem.
    - if the the revs do change then it could be timing related.
    - check inside you dizzy for excess oil. if none then its just the shaft o-ring that needs replacing.
    Veteran slide86's Avatar
    Huw
    Hills
    fuel pump
    Tim?
    Wild West
    ^ good point. no pressure could explain the hesitance and spluttering. if its running lean the exhaust cam cover will be alot hotter than the intake.
    Jay
    Shire
    The fuel pump runs... It makes noise? So mayb it's internally fucked and not making pressure.. Could also be why it idles rough?
    olympic gold keto
    Elite rthy's Avatar
    Leo
    Tulla
    do a comp test?
    id check the plugs, leads, cap and contact
  1. [BNE] Loss of power with smallport
    By timbo in forum Technical - Questions
    Last Post: 19th April 2010, 01:37 PM
  2. AE82 4AGE, Bigport or Smallport?
    By gumbie in forum Technical - Questions
    Last Post: 12th February 2009, 01:02 AM
  3. AE82/92 4AGE Smallport , Ignitor & Fuse/Relay Box for loom
    By csr in forum Cars or Parts Wanted
    Last Post: 19th September 2008, 10:09 PM
  4. AE86 vs. AE82 power steering racks
    By corolla_kid in forum Technical - Questions
    Last Post: 20th February 2007, 06:48 PM
  5. 4age Smallport Power Streeting and A/C
    By hugh in forum Technical - Questions
    Last Post: 28th July 2006, 02:03 PM
